Old 06-22-2019, 09:18 PM
SteinHDan may I ask what Infill % did you use for your model
Steve
Old 06-23-2019, 05:32 PM
It varies depending on how strong I need that part to be. I believe I've added some info about the infill on the various parts in this build. Typically between 10% (draft) 15% lightest production part, 20 for medium strength and 35-40 for very strong parts. I'm not often using > 50% infill, but if I need the strongest possible part, I would maybe do 75%, but usually I find the additional strength doesn't weight up for the additional print time.
Stein :-)
Old 06-23-2019, 07:54 PM
sounds good, Loving the machine keep up the good work
Steve
Old 07-01-2019, 09:43 PM
That excavator looks awesome
Old 08-16-2020, 06:22 PM
Cutting new windows for the excavator on a laser cutter:
https://youtu.be/9scmbmxY500
Stein :-)
