Old 06-16-2019, 02:24 PM
Default Re: Fumotec 490
That looks fantastic!
Old 06-16-2019, 03:15 PM
calum_scania's Avatar
calum_scania calum_scania is offline
calum_scania is on a distinguished road
Thank you, hopefully when the windows are in it'll look a little more finised
Old 06-21-2019, 03:45 PM
A few pictures of my cab, the window edges painted black before glueing the windows in.
The door with its window glued in. I still need to finish this off the black edging sticker supplied with the kit
Old 08-18-2019, 11:37 AM
Upgraded my Graupner gimbals for 4D versions, will give me the ability to use the aux functions now. A fairly cheap and simple upgrade although fairly nerve racking opening up a graupner radio
Also got a few hours on the 490 in my garden
Calum
Old 08-19-2019, 09:06 AM
It sure makes things easier
Old 08-21-2019, 05:24 PM
Yes would need to actually buy some attachments...
Old 09-03-2019, 02:23 AM
Those gumball controls look like they'd be nice to have. Much easier to use than the stock sticks, I'd think.
Old 09-09-2019, 04:11 PM
Load er up!
dice com mobile app
Old 09-09-2019, 06:19 PM
Looking good Calum, you have everything working to your liking now?
Old 09-10-2019, 03:10 PM
I think so Joe, haven't got many hours on it so far. My only problem is the stick cylinder - I can't decide if its faulty or not. It doesn't seem to have much power but maybe I'm expecting too much from it?
Whats the digging power of your 490 like?
Calum
Old 09-10-2019, 06:18 PM
I have my pressure turned down to 18bar, I dig in cultivated soil & it won't pull the model off its perch... if the stick with is pulling the model around, the pressure is too high... but with 14mm cyl bores on this model I don't think it's possible anyway... what do have your pressure set to?
Keep in mind raising/lowering pressure will greatly affect reaction speed too.
Old 09-11-2019, 12:52 PM
It's set to around 22bar, I'm not trying to dig up my garden or anything extreme. Just I feel it should have a little more power?
I don't have anything to compare it so maybe it's okay. Certainly digging sand it managed easily
Calum
Old 01-02-2020, 03:08 PM
Talking Re: Fumotec 490
Hello everyone,
A few small jobs on the 490 I've been working on. A stone guard has been added along with a beacon, i'll paint this at a later date.
I've also been fitting an adjustable pressure relief valve to the system, for this I had to remove all the electrics and re-locate them elsewhere. Still setting it up on the t/x but initially everything works smoothly and should hopefully improve my run times
Before I started
After I had re-installed everything
Regards Calum
Old 01-02-2020, 05:32 PM
Adjustable by remote?
Nice details, btw
Old 01-02-2020, 05:53 PM
Yes, servo operated - bit of head scratching trying to get it to run smoothly..
Calum
Old 01-02-2020, 06:19 PM
Hi Calum
i love the work and detail you have done on this and one day plan myself to build an excavator. if its as half as good as yours i will me more than happy !
as i am new to this whole world of RC goodness could you share me your tips on making/build this kind of detail? was it metal or plastic ? did you model it first?
thanks
Rob
Old 01-03-2020, 09:51 AM
Originally Posted by Originalrob View Post
Hi Calum
thanks
Rob
Hello Rob, I didn't design anything its a Fumotec kit
Here's a test video of the relief valve operating
Calum
Old 04-19-2020, 02:00 PM
Hello everyone an outside test with the adjustable relief valve installed
https://www.youtube.com/watch?v=hUVKDt6x97M&t=69s
Old 10-31-2020, 01:41 PM
trucker n's Avatar
very nice question where can i get the gymbals u used for your graupner radio
