Old 04-04-2020, 08:09 AM
Default Re: HIAB X-HIPRO 1058 loader crane
Here's a few pictures of assembled crane
Next I should probably start making the telescopic arm.
Old 04-04-2020, 06:38 PM
jack van's Avatar
jack van jack van is offline
looks real cool awsome work again
Old 04-05-2020, 08:58 AM
I got the third boom done, inside that will come the telescopic extensions
Old 04-06-2020, 06:16 PM
BlackCat BlackCat is offline
BlackCat is on a distinguished road
Thank you Hemi !
There any reason why you have choose steel over aluminum ?
I'm about to buy a Chinese knock off lampert welding machine and milling aluminum is way more easier on my cnc router... I'm scare the welding of aluminum is going to be bad. Seen some picture of peoples successfully weld with aluminum with those kind of machine. (Picture here) But maybe you already try and was not happy with it ?
Otherwise nice work again
Old 04-06-2020, 07:31 PM
avel avel is offline
I saw on another forum that somebody used a teflon tape between the telescoping sections for lower friction when telescoping the sections.
I think it was one of the German forums.
Youtube username iamaman27
Old 04-07-2020, 09:56 AM
Originally Posted by BlackCat View Post
Thank you Hemi !
Main reason I choose steel was just that welding. I have tried to weld aluminum, but I wasn't pleased with the results. But it could be just me not knowing what I was doing
Old 04-07-2020, 10:04 AM
Thanks for the advice. Do you have any idea what kind of teflon tape it was, the only one I know is for sealing pipes, but that might not be the correct one.
Old 04-07-2020, 04:54 PM
That's looking incredibly wicked, can't wait to see this working!
I'd guess the Teflon tape used on sliding parts like that would be something like a Nitto Permacel p-421. It's a silicone adhesive backed smooth sheet of PTFE 5Mil thick. Most of what i've messed with is 1" wide.
-- edit
Ptfe = PolyTetraFluoroEthylene = Teflon is the brand name.
Let me know if you can't track any down...
Old 04-07-2020, 07:24 PM
I think I used the wrong word. I was using google translate to read the forum. But yes it was something with an adhesive side and a slippery/low friction side.
https://www.modelltruck.net/showthre...PK100002/page3
self-adhesive PTFE film. Post number 78 is where I see it first mentioned.
Old 04-08-2020, 06:48 AM
ptsg ptsg is offline
ptsg is on a distinguished road
PTFE is the actual name of the material used in Teflon. Teflon is just a brand name that stuck.
Excellent work Hemi. It's coming out prefect!
Old 04-08-2020, 08:26 AM
Papy Papy is offline
I used electrical shrink tube with success, but this is relatively thick and so requires to be considered at the design step...
Old 04-08-2020, 10:10 AM
Thanks guys, I will look into those
Old 04-09-2020, 04:23 PM
This will be a STRONG boom, once the crane is done!
Old 04-11-2020, 09:00 AM
I made the base for the column
Old 04-12-2020, 12:02 AM
I admire your craftsmanship! If I were to try & scratch build a crane, like you've done I fear it wouldn't function very well.
Old 04-12-2020, 11:34 AM
That could very well happen to this one too
I mostly worried about the extension cylinders (6 pcs) placement and the routing of their hoses.
Old 04-13-2020, 06:00 AM
This is the slew gear
Old 04-13-2020, 11:53 AM
Wibb Wibb is offline
Wibb is on a distinguished road
Beautiful work!
Old 04-13-2020, 02:08 PM
Amazing machine work !
Old 04-14-2020, 06:51 AM
I made some pins and pin keepers today.
Tags
hiab, loader crane
