Old 05-06-2020, 05:15 PM
Default Re: Euclid R-62 dump truck
With the gear ratios you've got in the transmission what are your scale speeds?
I think you said you tried to stay close to the original ratios in the transmission, but the difference between your electric motor's max RPM and a diesel's max RPM could be why you need more reduction.
Old 05-07-2020, 06:39 AM
kerst's Avatar
kerst kerst is offline
With the current gear ratio top speed in scale 1/1 is around 25 mph. The real one can reach about 30 mph.
The electric motor should reach 5,500 rpm, while the diesels do 2,100 rpm.
Kerst
Old 05-25-2020, 10:21 AM
kerst's Avatar
I never thought I would get (into) electronics, but so far it seems to work out.
In the past weeks i worked on all the electric connections and finding space for the electronics, etc. Although the Euc has a huge hood, I had to try various setups in order to find the right setup that fits inside the hood and cab without being too visible.
I bought a 8 channel system. One channel for the speed control, 2 channels for the 4-speed transmission, one for the on-off-on switch for the tipping motor, one for the on-off-on switch for the driving motor and one for the steering servo.
Kerst
Old 06-26-2020, 06:53 PM
kerst's Avatar
I found the right paint for the Euc. It looks decent, the color is very nice but needs a second coat and I didn't buy enough!! That means waiting.
Kerst
Old 06-27-2020, 09:08 AM
JAMMER JAMMER is offline
Very nice job on the Euclid alot of thought went into it . Ed
Old 06-27-2020, 05:10 PM
That truck is a beast.... I can't get over the skill and attention to detail some of the builders have here....and this is just another great example.
Old 07-18-2020, 04:52 PM
kerst's Avatar
It took me just under 2 years to build this truck. It was a lot of fun. The transmission and the controls were the most challenging, but after a lot of tinkering it all works and it is fully remote controlled. The right stick controls the acceleration and the steering, the left one is for the 4-speed power-shift transmission. There are 2 other switches, one for forward, neutral and reverse, the other for dump hold and lower.
I found the right kind of spray paint and I am very pleased with the result. I still need to add some decals and I will also prop up the front suspension. The powerpack is quite heavy!
Kerst
Old 07-18-2020, 07:35 PM
That looks absolutely amazing!!!
Are there going to be covers for the passenger door esc, and right frame servo.
I still can't get over the work you put into the transmission, and would love to see some videos when you're ready
Old 07-18-2020, 10:05 PM
Kerst, just a marvelous build! Transmission is a masterpiece and final result is great.
Top notch project!!!!
Old 07-18-2020, 11:08 PM
diesel950 diesel950 is offline
diesel950 is on a distinguished road
looks good, been a long poject but rewarding to see finished.
now just to get it dirty
Old 07-19-2020, 07:53 AM
Mikem Mikem is offline
Looks fantastic
Old 07-19-2020, 08:53 AM
Glad you got this done Kerst. I guess with the big shut downs everywhere gave you time to work on something fun.
Old 07-19-2020, 09:54 AM
Amazing what you can do with lots of time. Ed
Old 07-19-2020, 11:55 AM
Jared Jared is offline
That looks great! Can't wait to see it loaded, starting out on the flat and then climbing a hill, downshifting on the way up.
Old 07-26-2020, 06:44 PM
rc_farmer's Avatar
Master Builder
Absolutely OUTSTANDING
Giving up is not an option!!!
Rob
Old 01-14-2024, 03:26 PM
kerst's Avatar
Working hard at the Cabin Fever Expo.
https://youtu.be/tmLzjhOGvMM
https://youtu.be/JH2VwbPnhyQ
Kerst
Old 01-15-2024, 12:20 PM
Nice to see it out working... looks great in the dirt...
Old 01-15-2024, 04:04 PM
That looks great out there!
When was CabinFever this year?
Old 01-15-2024, 04:23 PM
kerst's Avatar
During the past weekend.
Kerst
