Old 07-23-2020, 05:04 AM
Default Re: HIAB X-HIPRO 1058 loader crane
I got all the hard lines for the extension cylinders done.
Old 07-23-2020, 04:46 PM
Did you say you were going to use a sequencing valve, or that you didn't plan on it? Without a sequencing valve, whichever section moves the easiest is gong to be the section that moves first. Path of least resistance and all that.
Don
Old 07-26-2020, 11:05 PM
Don
I don't think there's room for sequencing valves. They should be located on the boom, or other wise I would need a ton of more tubing. I can adjust the movement sensitivity on each segment with a nylon set screws though. They are meant to adjust the side play of the segments. Will just have to wait and see how is going to work.
Old 08-15-2020, 05:46 AM
This is going to be the chassis for the crane
Old 08-15-2020, 06:54 PM
Awesome work, as usual, Ari!
Old 08-18-2020, 09:55 PM
BEEFY!!!
Old 08-30-2020, 09:15 AM
I've been working with the front support legs mountings
Old 08-30-2020, 10:23 AM
Darn...just Darn... the precision is just incredible my hat is off to you sir.
Old 09-13-2020, 05:34 AM
Some progress with the front supports
Old 09-13-2020, 04:24 PM
thercfreak2012 thercfreak2012 is offline
thercfreak2012 is on a distinguished road
Smile Re: HIAB X-HIPRO 1058 loader crane
You gonna be using a brixl radio With that setup?
Jake
Old 10-31-2020, 05:45 AM
No, I got the Servonaut HS16 radio.
Old 10-31-2020, 05:54 AM
Hi guys, it's been a slow progress with this, but I got something done.
I got the slew motor mounted, and made some brackets to mount the crane to frame.
Old 10-31-2020, 07:48 AM
kerst's Avatar
kerst kerst is offline
Beautiful!
Old 11-02-2020, 03:39 AM
3d printed cover for the slew motor
Old 11-09-2020, 10:24 AM
I made design changes how to mount the crane to the frame rails, here are some new parts
Old 12-04-2020, 06:02 AM
I got the bed pretty much done. It's all brass, except sideboards and posts. It's soldered together.
The sideboards and posts are removable.
Old 12-04-2020, 11:13 AM
I got the sideboards done
Old 12-04-2020, 11:54 AM
frizzen frizzen is online now
Wow. That machining is beautiful.
Awesome looking truck
Old 12-04-2020, 12:09 PM
Tgrzes Tgrzes is offline
Tgrzes is on a distinguished road
Very nice!! Looking forward to seeing it in operation!
Old 12-05-2020, 12:19 AM
Brel's Avatar
Brel Brel is offline
A fantastic build, way beyond my engineering skills
Tags
hiab, loader crane
