Old 09-10-2020, 06:42 AM
watsonbill watsonbill is offline
watsonbill is on a distinguished road
Question Help Crane builders
Hi,
I wonder if any one can help me?. I am building a Leibherr LTM 1030 2.1 crane, and cant figure out how to get the boom to extend. I understand the full size principal, but cant see how to get a 1/14 scale boom to extend.
Most articles I have found seem to miss out the extending boom ,other than to show it working
Bill Watson
Old 09-10-2020, 09:05 AM
Default Re: Help Crane builders
https://www.the-blueprints.com/vecto..._mobile_crane/
Are you stuck on Telescoping the hydraulic boom, or Swinging the lattice boom onto end of other boom?
Is your model running hydraulics, or are you doing it electrically?
Old 09-10-2020, 02:21 PM
watsonbill:
RC Modders did a series of YouTube videos on his Bruder CAT Telehandler conversion. There are several dealing with just the boom, including the boom extension. This is electric control, not hydraulic.
On my Manitou conversion, https://madmodder.net/index.php/topic,13026.0.html I plan on using a length of 5mm 3D printer leadscrew, but then I'm only trying to animate one section of the boom. Even then it's going to be a tight fit hiding the gearbox inside the boom.
I've figured out a way that with minor modifications to the transmitter, I can use 2 channels to control the speed and direction on up to 5 motors, but only one motor at a time. I plan on using 2 of these set-ups on my Manitou, which will give me the equivalent of 10 channels of control from 4 radio channels. I doubt that I'll ever be coordinated enough to try controlling multiple movements at one time. I don't see not being able to do simultaneous coordinated slew, boom, and cable movements as a problem.
Don
Old 09-10-2020, 09:50 PM
Originally Posted by watsonbill View Post
Hi,
Bill Watson
Hey Bill what if you used some firgelli actuators in each section of the boom? not sure how your funding is but......
Steve
Old 09-11-2020, 05:22 AM
No Hydraulics, just electricc power. Yes, stuck on how to build telescopic boom.
Thanks for reply
Bill Watson
Old 09-11-2020, 05:24 AM
Problem is I need to move four sections out and in
Old 09-11-2020, 05:26 AM
Dont see how that would work as each section slides inside the next one
Old 09-11-2020, 05:27 AM
Electrically and Yes! stuck on extending boom
Old 09-11-2020, 09:15 AM
That's an interesting one. Since you said no to the Actuonics option, maybe one of these?
Gear tracks mounted to booms, with gearmotors running the pinion gear. Possibly either individual escs, or 1 esc with many micro switches to sequence sections and limit travel
Jackscrew and acme nuts mounted to booms, coupled to gearmotors, controlled as above.
Continious-rotation Servo set up as winch drum, pulling line through complicated system of pulleys to extend. Springs or second cable bed on winch drum to retract sections? Possibly sequencing the sections by different retract spring rates on each section?
. Something like. https://www.youtube.com/watch?v=yInMEfrQWwA
. Or. http://sariel.pl/2008/12/mobile-at-crane-6x4x2/
Post up a build thread!
Old 09-11-2020, 11:10 AM
Papy Papy is offline
As far as I remember, older 1030 cranes had a cylinder moving the first telescoping element and a cable/pulleys set up that "synchronised" elements 3 and 4...drop me a PM and I can send you a pdf brochure showing in detail how it works.
Of course, the cylinder can easily be replaced by a gear motor/screw combo
Old 09-11-2020, 04:04 PM
Bo Wallen's Avatar
Lightbulb Re: Help Crane builders
https://www.youtube.com/watch?v=IFS1jcR66GM
Old 09-12-2020, 05:50 AM
Originally Posted by Bo Wallen View Post
Thanks for reply, but difficult to miniaturise to 1/14 scale!
Old 09-12-2020, 08:57 AM
kerst's Avatar
kerst kerst is offline
These might be helpful:
http://www.liebherr-datasheets.dk/other/TP21.2.3.79.pdf
http://www.liebherr-datasheets.dk/ot...21c.1.8.86.pdf
Kerst
Old 09-13-2020, 05:39 AM
Thanks for reply, now got to do a bit of reading and understanding.
