Sound Systems tech This section is dedicated to the sound systems for our models. Tamiya MFU, Servonaut, etc. |
I've bought a Chinese knockoff Servonaut sound board from wbtcar (Lesu, I think). No instructions came with it, just a wiring diagram. I've got it wired in to the truck as shown, the green light on the board lights up, but no sound.
While installing it, I noticed a programming plug labeled "remove for set up", so I tried that way, but still no sound. Does anyone know the setup procedure for these boards? HELP!
WILDCAT T&C Jim B. Colorado Springs |
Thanks for the help, blitzk!
Found my problem, I was trying to run the sound from the throttle stick without going thru the start up procedure on the other control stick. NOwhere is this explained anywhere. Here's what I mean; https://www.youtube.com/watch?v=E-3ADvABQks Good to know on blitz's link there are 4 other functions that can be accessed for setup. Thanks!
Hi all, new here and have a question for you. I bought one of these boards and put it in my Tamiya Scania which for all intents and purposes, works well. I set it up as per the standard instructions and have my truck running with a Spektrum DX6 transmitter.
My question is, can you adjust the matching of the revs to the position of the throttle stick somehow? As it is, it sounds good but I’d kinda like it to rev higher earlier in the throttle stick position.... Sorry if this is a bit of a newb question. I look forward to your guidance. Thanks very much Kurt |
This thread is kind of old...might get better results if you start a new one....
Thanks Jerry56, will do.
Cheers Kurt |
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests) | |
