Old 08-19-2010, 03:34 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default Silverado Dually in 1/14
This seemed like the most appropriate forum, if not mods/admin will move.
I got a new bright Silverado from my wife because it was a black friday deal for 20 bucks or something.
In the box:
Out here in AZ where it's paved and flat I have seen quite a few construction and landscaping company owners that drive street style duallys. I keep meaning to snap pics of one I have seen a couple times but I never have my camera. So my idea was to hack this body (gave the chassis to my 5year old son) and build myself a dually.
Build materials:
New Bright Body to be hacked and modified
Tamiya Semi Rims front and rears
Tamiya 60D Tires
RC18R Front Clip (indy instead of solid)
Wedico or Tamiya Semi Rear axle depending on width
Some mock-up with stock cab and rear aluminum rims not for this build:
First issue is the tires. They are 1.5 and stretched to 1.7 they cave badly. Also they are a little wide for duals:
Compared to stock semi tire:
First I tackled the fronts that I plan to leave wide. On the right is the tire with no foam and left is with 60d hard foam inserts:
Still not good enough so I cut out the ribs in the center of the semi rim and laminated styrene (sorry the pic sucks):
The final result is on the left:
Old 08-19-2010, 03:38 PM
sneaky-pete's Avatar
Master A-Modeler
Default Re: Silverado Dually in 1/14
this will be cool
Troy
Old 08-19-2010, 04:53 PM
CorbettTrailers's Avatar
CorbettTrailers CorbettTrailers is offline
CorbettTrailers is on a distinguished road
Now this is something new. I like it. I'm a huge Chevy Fan!
Old 08-19-2010, 10:08 PM
trucker n's Avatar
love it
Old 08-20-2010, 01:49 AM
trucker n post whoring all over the board.
I took a size comparison shot of the semi vs 60d tires unmounted:
And here is a comparison of the width after narrowing the 60d's to the semi tire:
Narrowed vs un-narrowed 60d's mounted:
Front clip from 18r seems to be a good width (shown with 18r wheel/tire):
I do have an issue with the stub axles though. Stock 18r's are to short so I had to order the 18t's (left)
Latest issue is that the stub axle is 4mm at the pin location and 3mm for the rest. I am not planning 4x4 yet but could add later. To mount up the stock semi rims I need two 3x11 bearings. McMaster only has 3x10. I found them at boca but they are 20 bucks a pop! Anyone know where I could get some cheaper?
Old 08-20-2010, 04:32 AM
CatdrvR's Avatar
CatdrvR CatdrvR is offline
CatdrvR is on a distinguished road
This is a very cool project you have going. I think it's pretty interesting you are using the front clip of an 18r but it does seem to fit rather well. I probably would have never thought to use it. The idea of a street dually is another intriguing thing... I have never seen one up here in the northeast. Can't wait to see more pics of the progress.
Dan
Old 08-24-2010, 07:19 PM
I cut the bed off (razor saw):
Then I put the cab rear back on in preparation for cutting the cab off at the door seam:
I cut the rear edge off again (thread method) and inserted the crewcab doors:
I still have a lot of detail work to get done on the body. Somehow have to get crewcab door seam in the ABS body.
Old 08-25-2010, 09:35 PM
DieselKid's Avatar
Nice start to a neat build! Gotta love those low-pros on a pickup!
Must be a warm weather thing....you say you see them out West and I've seen them down south in FL...no matter the locale it's a menacing look for a truck to be running 22.5s!
And neat tutorial on the tires....thanks. I think we are all in need of ideas for low-pro options when it comes to tag axle and certain trailer builds.
Will be keeping on eye on this thread,
-Alex
Old 08-26-2010, 09:10 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Interesting build. Have to keep an eye on this one!
Old 08-26-2010, 09:41 AM
JAMMER JAMMER is offline
Smile Re: Silverado Dually in 1/14
Mat you got a good start there. Why don't you look at 4x4 form there is a guy selling aluminum scale bodies and you will have your extra door. Only a suggestion. Ed
Old 08-26-2010, 12:22 PM
Thanks Alex & Lynn.
Ed, the body I am working with is 1/14 to match the big rigs. The metal bodies I saw were 1/10. Did I miss something? Doesn't seem like there would be money in making a niche 1/14 silverado. None the less I am already committed to the styrene shown here.
I have the roof on now and another layer of styrene on the doors, but no pics yet. The first coat of filler and sanding to start soon. I was hoping to get some frame rails cut this weekend but wife's birthday bash for 60 or so people is on Saturday so I probably won't make much progress on those till next weekend.
Old 08-26-2010, 02:05 PM
I definitely would not miss that if I was you if you know what I mean. Ed
Old 08-26-2010, 03:58 PM
Will the silverado just drive around or will work like pulling a trailer?
Old 08-26-2010, 06:40 PM
Working of course. Not sure if I will do a 5th wheel plate or gooseneck hitch.
Old 08-26-2010, 07:01 PM
firefighter30's Avatar
firefighter30 firefighter30 is offline
firefighter30 is on a distinguished road
I have a f350 1/10 scale going to take the bed off and try to make a 1 ton dump.
Old 08-26-2010, 09:37 PM
Diesel Demond's Avatar
another build i cant waite to see being a huge duramax diesel fan!
Old 08-26-2010, 11:58 PM
Laid out the wheels/tires for fun:
Got the roof and some add'l detailing done. Threw a light coat of primer on part of it:
Old 08-27-2010, 09:40 AM
With all due respect. I noticed these on tower hobbies. 4 for $7.99.
Wasn't sure if you still needed them.
Later,
John
http://www3.towerhobbies.com/cgi-bin...3x%3C%2FB%3E10
ECMT Members: Join your Group. Go to your username in the top right corner of the page and click on it. When your profile opens go down to group memberships, Click on East Coast Mini Truckers, The social group will open and scroll down And in the middle it you will see "Join Group" Click on it and then confirm that you REALLY wanna join.
[SIZE="2"]
Old 08-27-2010, 10:14 AM
John - 3x10 are easy to find it's the 3x11 I need that are hard to find. I think I have a solution that will only cost a couple bucks. Parts in the mail.
Old 08-27-2010, 10:42 AM
Thorsteenster Thorsteenster is offline
Thorsteenster is on a distinguished road
Nice find on the body, and great work. It's really coming along and will be sweet to throw some variety into the vehicle mix at meets.
I think I have some 3x11 flanged bearings at home. I can throw a mic on em and double check if you need a couple few.
