Old 01-28-2011, 02:30 PM
texken's Avatar
texken texken is offline
texken is on a distinguished road
Default Liebherr LTM 1030-2
Does any one know where to find metal for the Telescoping Boom?
Aluminum Square would work also.
Scale 1/25
Texken
New member
Old 01-28-2011, 04:33 PM
Default Re: Liebherr LTM 1030-2
Check the K&S site. You will no doubt have to machine one down to fit inside another unless you can install nylon bushings to tighten them up.
Old 01-29-2011, 12:22 PM
mog mog is offline
i would make shere that i would use some thing like nylon as 9W said. if you have aluminum on aluminum it will gull up in no time flat a steel one and aluminum core would work fine but aluminum dose not like rubbing on it self and you will be stuck with a big mess in not time i found this out the hard way. i eavin whent as far as too try lube like graphit spary and just about evey thing els i could think of steel on steel works the best that what some of the real picker use.
Old 01-29-2011, 02:57 PM
If you can anodize the aluminum parts they would slide better. But not real well for very long unless it was a hard coat,meaning the temperature of the water it was anodized in and length of time. (don't mind me I was just rambling)
Old 01-29-2011, 03:04 PM
texken's Avatar
Thank you, good on nylon
Old 01-29-2011, 03:06 PM
texken's Avatar
K&S two small I looked but thank you
Old 01-29-2011, 10:58 PM
tracksntreadslou's Avatar
You may be able to add small rollers on each end ...I would check your local metal recycling depot..Some will have an area that you can shop in ...I find very many and different profiles there and at scrap prices
Old 01-29-2011, 11:35 PM
http://eaglemouldingsinc.com/TubingS...ularRound.aspx
Somebody else posted this link the other day, any help to you?
Later, Neil#2 aka doodlebug.
Old 01-30-2011, 03:16 AM
texken's Avatar
Hi doodlebug, wow think I went to heaven.
I think I found my boom
thank you,
ken
Old 01-31-2011, 12:22 AM
Yer Welcome!
Old 02-02-2011, 06:55 AM
texken's Avatar
doodlebug
need to be sitting for this.
Eagle only sell 24' long tubing.
Went to ALLMetals, got steel tube.
Was nice you tried to help, thank you
texken
Old 02-02-2011, 10:46 AM
Hey texken, I found this outfit in Live Steam magazine. No minimum?
http://www.speedymetals.com/c-8364-r...ular-tube.aspx
Old 02-02-2011, 12:01 PM
texken's Avatar
Thank you.
Will look
texken
Old 02-02-2011, 12:06 PM
steamer's Avatar
steamer steamer is offline
Here's another link and they sell in four foot lengths
http://www.brunnerent.com/Tools/Port...=0&iPageView=0
Rob
Old 02-06-2011, 11:20 AM
Here's a link from another forum showing what the insides look like. As you can see it's pretty complicated to make a telescoping boom.
http://forums.dhsdiecast.com/default...posts&t=128642
Old 02-09-2011, 01:54 PM
texken's Avatar
Default LTM 1030 update
Well with help, have found telescoping boom, wheels, and how to mount crane to chassis.
Now need how to raise boom, no hydro way.
Found motors for swing, and winch. Also for boom extension.
Your helping was great, thank to all. Input welcome
TEXKEN
Old 02-09-2011, 04:52 PM
Default Re: LTM 1030 update
Ken , Are you going to make this a build thread ? If so do tell so we can move it to where it belongs it is in the wrong place if it is . it'll be great to see more crane builds
IHSteve
Old 02-09-2011, 05:35 PM
texken's Avatar
Yes please move to better place.
TEXKEN(ken)
Old 02-23-2011, 10:14 PM
texken's Avatar
Well I layied the Keel Sorry I have built to many RC ships. I meant Chassis to day.
Aluminum deck, will have Aluminum Crane.
So will slowly start working on other parts.
Found Telescoping boon, still no wheels, need to be small hub, 4 1/2 in tires.
Will be using Chaseracer's system to raise the boom, just motor on other side.
If it works will share. LOL
Later,
TEXKEN Ken
Old 02-24-2011, 12:51 PM
texken's Avatar
found wheels
texken
