Old 02-14-2011, 10:17 PM
Operator's Avatar
Operator Operator is offline
Operator is on a distinguished road
Default WELCOME TO THE ROCK FARM
Hello,
I decided on my first build. This past summer we rented this tracked closed circuit portable horizontal shaft impact crushing plant. I ran it for about 400 hours, It was fed with a 400 Komustu. Its pretty cool rig, you have a remote with you in the hoe that you can turn all on, and track it where ever you want with the remote. It was taking 24" by 24" pieces of concrete and recycle it til it would pass the 1-1/4" screen. Pretty small, compared to the other big plant we use, but still would produce 300 ton an hour.
So there it is. I'm taking the plunge. All you track fabricators, go ahead and chime in, and help me get started. The conveyors, Impactor, and feeder I think I got a pretty good handle on how to go about building and making functional, but I need some help designing the tracks and drive components.
Rock Farmer
Matt
Old 02-14-2011, 10:28 PM
RCTech9's Avatar
RCTech9 RCTech9 is offline
Default Re: WELCOME TO THE ROCK FARM
I assume your going to build in 1:14 scale. This will be a cool build. i will be watching this.
Old 02-14-2011, 10:44 PM
Is the impact crusher better/more efficient than a jaw crusher?
What sort of material do you plan to put through it to demo the model?
Old 02-14-2011, 11:15 PM
RCLogger's (Greg) tracks are rather simple to manufacture & quite effective function. (scroll to the bottom & next page)
Old 02-15-2011, 12:26 AM
Rogue's Avatar
Rogue Rogue is offline
Rogue is on a distinguished road
We ran 2 Lippmann HSI's on the last portable plant I worked, in a closed circuit, being fed by ElJay screen decks. Along with a Lippmann 30x42 jaw. I do not miss having to hand dig one clean after a curtain liner drops free, and grenades the internals.
We could avg. right at 280 TPH the way we were set up here.
Should be a cool project. I know a couple have already been done before yours. I'll have to do some bloodhound work, and track some vids down for you. If you need any blueprints or schematics, shout out, I still have some contacts I could call in for you.
Rick.--- I suffer from Wedicosis
My other truck is a Komatsu
Old 02-15-2011, 06:01 AM
Hey Matt, this is the (little) monster, that I play with on a part time basis.
http://www.rrequipment.com/PDFs/CRUSHALL_InfoCR75.pdf Later, Neil#2 aka doodlebug.
Old 02-15-2011, 08:01 AM
SmallHaul's Avatar
Matt,
Cool project. You should enjoy building this machine. I am making chain driven tracks for my cable hoe and it is quite a learning experience. The tracks and pads are copied from Greg (RCLogger) thanks Greg. Everything you need to make is fairly simple though...spacers, shafts, idlers. There are lots of options for chains, sprockets & pre-made conveyer belts too.
Good luck!
Scott
"No load is too Small"
Old 02-15-2011, 11:24 AM
Operator's Avatar
Changing Blow bars every other day sucks too!
Old 02-15-2011, 11:28 AM
Operator's Avatar
It works better for recycling concrete. It busts the material away from the rebar.
Chesse balls! Hopefully I'll make specs!
Old 02-15-2011, 11:50 AM
D8R D8R is offline
Looks like a unique project, guess you don´t need a RC for that, just start the engine and let it run.
Dan
Old 02-15-2011, 01:11 PM
Operator's Avatar
Dan
The tracks will be RC, also the speed of the feed, belts on/off, and the speed of the impacter, will all be controlled by RC, just like the real one.
Matt
Old 02-15-2011, 01:22 PM
Operator's Avatar
A little more info on the chain please. Whats the K-1 tab? Mcmaster or MSC got this stuff? Part #'s.
What do we use for drive motors? 540's separate speed controls? Will the new receivers accept more than 1 speed control? I'm going to need at least 9 separate motors and controls for this project.
Alot of things have change since 1988 when I last started RC cars. My first Speed control was a Novak T-4 back in 90'. I'm not up on whats available now.
Thanks for your help,
Rock Farmer Matt
Old 02-15-2011, 01:35 PM
I'm looking forward to this build. You wont need too many speed controls you may get away with just 12 or 24v gearmotors from a power supply or one 110v motor through gear reductions or chain and sprockets or cog belts. Look over ebay. I spend hours scrounging for parts that may work for projects. Here's a video I came across on youtube of a mobile plant that crushes plaster. This guy even has a hammer for his excavator. I think LilGiants has a crusher he uses in his basement PIT.
http://www.youtube.com/watch?v=jWSbW...er_profilepage
Old 02-15-2011, 02:01 PM
It's just a vertical dirt lump crusher for hard clay lumps. I'd like to have a jaw crusher for busting actual rock.
Old 02-15-2011, 05:01 PM
Operator's Avatar
Old 02-15-2011, 05:44 PM
SmallHaul's Avatar
Matt, after re-reading my post it almost sounds like I am saying your build will be easy. But, what I meant was dealing with the chain setups won't be to bad... The whole build is actually a large complex project that should keep you very busy.
Scott
Old 02-15-2011, 06:38 PM
Operator's Avatar
A piece at a time. Should be fun.
Matt
Old 02-15-2011, 06:42 PM
Operator's Avatar
Would like a link to conveyor belt material.
Matt
Old 02-15-2011, 07:40 PM
Operator's Avatar
I see Mc Master Carr has all the belting, lacing, roller chain, sprockets, and K-1 links.
Matt
Old 02-15-2011, 08:19 PM
Operator's Avatar
