Old 02-18-2011, 11:21 PM
Operator's Avatar
Operator Operator is offline
Operator is on a distinguished road
Default Re: cnc ?
Originally Posted by fhhhstix View Post
I was at my local machine shop yesterday and watched him work for a little while and he has the butterfly wrench set up on his mills and it is a real slick way of changing tooling.
Travis
Slicker than snot, for cheap
http://home.insightbb.com/~joevicar3/cheap_drawbar.htm
Old 02-19-2011, 12:04 AM
Default Re: cnc ?
Thank's Matt, the picture explained everything! Later, Neil#2 aka doodlebug
P.S. Which crusher's do I need to look at next month ( conexpo/conag/ifpe show)?
I will be taking picture's!
Old 02-19-2011, 08:34 AM
Default Re: cnc ?
Originally Posted by Operator View Post
R-8 tooling is all you need, and is everywhere cheap. Make a power drawbar for about $50 out of a small air cyl, and a HF butterfly air wrench. This is about as quick as it gets to changing tooling. Unless your running a production shop with employee's, save your dough for extra endmills, you will need them though your cnc programming learning.
already have the quick change w/draw bar and R8 wont fit this baby , It takes NST#40 . what I got yesterday for $125.00 is worth up to $1000.00 now I just need more cutters and a 3 phase converter .
Steve
Old 02-20-2011, 12:30 AM
Default Re: cnc ?
Hey Steve, do you want to buy or build the 3 phase converter, Let me know, I can steer you toward's DIY if you are interested.
Later, Neil#2 aka doodlebug.
Old 02-20-2011, 01:21 AM
Default Re: cnc ?
Neil , I may be going that route since the quote I got on a VFD/inverter . I had a 20 hp RPC and sold it a month before I got the mill ( kicking my own azz ) the prob with that 1 it took all the amps I had supplied to the barn every time I fired it up . I saw a place in NY that sells panels already wired up you just get the motor . Now , I've been reading that your ph converter should have more hp then your load I'm thinking of going 10 hp for 5hp .
Steve
Old 02-20-2011, 11:43 AM
pugs pugs is offline
Default Re: cnc ?
Double is the recommended for CNC stuff, also make sure the legs are balanced under load
Jeff
Old 02-20-2011, 06:32 PM
Default Re: cnc ?
Steve you are correct, Now the thing that I don't know how to do is? Add capasitor's to the rotary convertor, and make it more efficient. The home brew rotary convertor's are like briggs & strattons, pull the rope, then throw the power switch. Hope this help's a little bit. Later, Neil#2 aka doodlebug.
Old 02-20-2011, 06:47 PM
Default Re: cnc ?
Aw heck I'll just go find as big a 3 phase motor I can find And put it behind a 400 bc3 cummins my wife just said to me today " will you just make parts and not tools also ! , we'll get the converter ! " my impatience are a killer . I'm starting to understand the programing I read my manual once and it didn't stick now second time around I'm working on programing back side of hub , hex and bolt pattern . taping I'll do by hand for now .
IHSteve
Old 02-20-2011, 06:56 PM
Default Re: cnc ?
Jeff I was told that to , also that you should separate the control power from the motor ? Which I did and the control works well . I may have to up grade the Z card in the future also want to put a 4th axis on it some time . I just got to find the parts .
Steve
Old 02-20-2011, 07:00 PM
Default Re: cnc ?
Steve I have 3 phase in my shipping container/shop, But I'm not a 3 phase expert! I still call the sparky when I have questions!
Old 02-20-2011, 07:56 PM
Default Re: cnc ?
Steve, won't be long you'll be doing parametric programming with subprograms and variables and custom macros
Good luck
Jeff
Old 02-20-2011, 09:50 PM
Default Re: cnc ?
Arrhhh I want to cut my dozer pads I can't wait much more
Neil I'm lucky to have a bunch of sparky friends from the construction industry + my parents neighbor is an PE in EE ,ME and some others they have a plant design co. where they set up assembly lines although they have no experience with phase converters but thats not taking me long to get straightened out .
IHSteve
Old 02-21-2011, 12:40 AM
Default Re: cnc ?
Hey Steve, sound's like thing's are under control!
