#141
I got a little more done by adding the cab-
![]() I made this part removable since I may have to use this space for R/C gear- ![]() Now back to work----well maybe monday. |
#142
Looking good, will be a one of a kind model for sure. Have had toughts about a 777 to but that will be years ahead. So many project to build, so little time.
impressed of those tires, best looking so far. Dan |
#143
Looking real good, you are moving along very fast. What is the scale of the 777 ?
Also what are you going to use on the dump box for power greg |
#144
D8R-thanks-I chose the 777D because it is an earlier model and it goes well with my Marion shovel model. I have found a better way to make the tires to get a smooth finish on both sides so if the truck turns out really good I may make new tires. RCLogger-thank you-the truck is an odd scale (1/30). When I built the Marion shovel model I knew the 1-1 machine was really big so I made a drawing the size I wanted the model to be and it came out to 1/30 scale so I went with that. Then I made the truck to go with the shovel model. I will use a screw drive to lift the box and even that will be a challenge because there is very little room to work with. "Freddygeardrive" is going to help me with that and I'm sure I will need his expert guidance. I have a lot more work to do but I am enjoying it a lot.
#145
I have decided not to use brass on the dump bed. It cost about 8 times more than steel but the main problem is that I cannot get the sizes I need in the flats for the braces. I would have to buy bigger sizes and machine them down to the exact size I need and this would involve a LOT of labor. Plus I would have to buy a radius cutting mill which is quite expensive so all in all it would have been a costly and time consuming deal so I decided to go with steel. I have the bed cut out and ready to put together-
![]() I got a local sheet metal shop to shear me some pcs. for the bracing. The cuts are smooth and straight and all I have to do is cut them to size and bend them into the shapes I need and braze them on. ![]() I have hours of brazing to do but then hopefully I will have a dump bed. That's all for now. |
#146
Better way to make the tires, you´r kidding, the ones you have now looks real good. Was it not possible to get the shop to bend U profiles for the bracing? that have saved you a lot of time.
Following progress, keep pics coming. Dan |
#147
D8R-the metal shop had problems cutting the small pcs. that I needed so I don't think they could have bent the shapes on their huge brakes. I have a small brake so I can bend the pcs. into the shapes I need.
#148
Well I got the dump box together after a lot of problems. I had to give up on the brazing because the thin metal would not take the heat without warping and twisting. I used a low-temp silver solder and it seemed to stick okay. Not as good as brazing but I had no choice.-
![]() I brazed the braces on the sides with them clamped down on the table but I knew I couldn't clamp the box together- ![]() ![]() I made one pc. of hand railing and using the norscot model I have the railing should be made with .090" wire but it looks big to me. If anyone knows the O.D. of the rails on these trucks I need to know what it is- ![]() ![]() I also made some of the detail pcs. while I was working on the box- ![]() I still have a lot to do on the box but hopefully the hard part is done. |
#149
Nice looking 777. Don´t know if Cat has standard size of railings, but on the D8 all are 1" tubing.
Like those wheels too (:>) Dan |
#150
Tom
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Mike "DREAMWEAVER" Johnson To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. RIP FreddyGearDrive 2-12-59/12-19-11 Rims and Tanks by ihbuilder / Grill and Visor by Brian in PA / Mirrors, Front and Rear Bumper, Back of Cab Lights, and Steering Arms by tc1cat / Fenders by Stylin n Profilin / Frame Rails by The Late Freddy Gear Drive |
#151
Looks good!
Kerst |
#152
Great looking truck
![]() Lynn |
#153
You sure are working fast. I figured you would have to go to the solder.
#154
tom you sure are a master
#155
That looks great! Wheelbase doesn't look so stubby now with a box on it.
I'd take a stab at 1" railings. |
#156
Hi Tom, it's looking really good and heavy. Awesome steel work. Keep up the good work.
How did you cut the holes for the headlights? |
#157
Thanks everyone for the comments and input. On the handrails if I use 1" tubing as a guide that makes the rails .033". That looks way to small to me. I think I will try .060" wire which I used on the shovel and it looks right. I may make a small pc. and post a picture. Lorenzo-I milled the headlight holes using an .062" cutter. I had to go really slow but it worked.
#158
wow nice fab work love it....
LARRY,the doggy dish dealer |
#159
Woah, you made a ton of progress, fast! That dump box and the cab look great! Nice to see you stuck with metal. By far nothing looks as realistic, when painted up. Can't wait to see the next update!
Nathan |
#160
Really looking good there Tom. Nice metal work.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
Thread Tools | |
Display Modes | |
