Old 03-10-2011, 04:40 PM
eef7260's Avatar
eef7260 eef7260 is offline
eef7260 is on a distinguished road
Very nice progress Steve the spokes came out real nice.
Are the 19 sheaves for the suspension ropes all the same or a lot of different sizes ?
How is the flu ?? ( over here it does not feel very pleasant )
Eef
Old 03-10-2011, 05:03 PM
Eef
They are all the same 20''dia -1.25''scale there are two more called deflection sheaves that are mounted on a small A frame 3/4 up the boom about the same dia. only they mesh together,one with a male flange and the other a female flange. They run on a shaft and can slide back and forth about 3/4'' with the cable swaying and following the spooling and unspooling. I think Lorenzo's Page dragline has a similar setup but closer to the house. I need to get the delection sheaves done, attach the wood planks on the tip and fasten two truck tires (I'm using Lego tires like on Smallhaul's Tonka)
to keep the cable from rubbing the lattace. I noticed some rubbing but nothing major from the Cabin Fever run.
As far as the Flu, I'm only in one day with the Amoxicillin. but getting a little better.
Old 03-10-2011, 05:13 PM
td9clyde td9clyde is offline
Dozer Builder
ya need to chill out and take care of yourself and get better then start buildin again lol hope you get better soon then back to buildin
Old 03-10-2011, 09:01 PM
I got the chance to see the boom for this masterpiece in person at the east coast show and it is just unbelievable the detail and craftsmanship are second to none good job Steve.
Travis
Old 03-10-2011, 09:42 PM
SmallHaul's Avatar
Nice progress Steve. I hope you are feeling better soon.
Scott
"No load is too Small"
Old 03-16-2011, 01:49 PM
Been working very slow lately. Thought I'd post a couple from this week.
Setting up boom to mill the chords to proper length
Now I need to make plates and attach to the ends so the channel that holds the front pillow block on can be mounted.
That wood block I used temporally for the point sheave came in handy to hold everything in alignment.
I miscounted the quantity of 1.25'' sheaves needed. I still need about 5 more and 4- 1''dia.
This is the first side then I will flip them over locate to one of the holes and continue milling the pockets.
Old 03-16-2011, 04:43 PM
eef7260's Avatar
Looking good Steve
See that you are running production on the sheaves.
You are going fast.
Eef
Old 03-17-2011, 08:52 AM
lorenzo lorenzo is offline
lorenzo is on a distinguished road
Interesting clamp configuration .
Did you turn the small sheaves manually or via cnc?
BTW: did you get my last pm?
Old 03-17-2011, 10:11 AM
Eef, I want to get these done. I want to move on to other things on the boom. Pretty boring on the milling operation. It takes 9min.ea to drill the 6 holes and pocket the spokes for the 24pcs. This evening I'm going to program the other side.Probably take close to 15min. each. I could probably go faster but risk breaking my 3/32''carbide endmill. I still need 6 more sheaves that are different size.
Lorenzo, I made each one on my lathe manually:bore,groove,part off, face to thickness.
Old 03-17-2011, 10:35 AM
Oh, very time consuming and boring work. I don't really like those kind of work.
But never the less they look like if they are done by cnc. Keep up the good work.
Old 03-18-2011, 12:42 PM
Finally got this set done. This is enough to reeve the boom but I still need a a couple smaller to run down to the boom hoist.
Collet fixture to hold in mill
view showing groove for 1/16'' cable
Old 03-18-2011, 03:33 PM
kerst's Avatar
kerst kerst is offline
they look beautiful!
Are you going to use ball bearings?
kerst
Old 03-18-2011, 03:40 PM
D8R D8R is offline
Nice wheels, have to get a CNC machine sometime. Was a little surpriced when visiting the show in Germany last november, there was manufactors showing CNC equipment, had never thought about that modeler should be those machines. Now when looking here at the forum I see more and more modeler using those.
Dan
Old 03-18-2011, 05:16 PM
pugs pugs is offline
Nice looking work as always.
Jeff
Old 03-18-2011, 06:03 PM
Hey Steve, you mentioned a while back, about changing the toggle switch's on your controlbox? Have you seen the joystick controler's in the Automation direct catalog?
http://www.automationdirect.com/adc/...etal/Joysticks I'm planning on using these for my grader project
(1:1) And alot less than what Grainger want's for sqaure d or telemechanique
Later, Neil#2 aka doodlebug.
Old 03-18-2011, 08:07 PM
Thanks All
No bearings Kerst, These will run on bronze bushings. They don't rotate enough to ever need ball beraings. The deflection sheaves will run on a bushing too. Those are next to machine.
Old 03-18-2011, 08:16 PM
Neal, Thanks for the link. This is what I was talking about, I was thinking of taking the guts out of a DX6 or 7 and installing them in these controls from a real machine. I still need swing pedals though. I could eliminate the radio all together and go thru a slip ring with more conductors also.
Old 03-18-2011, 09:18 PM
hmmm, for short range and the room you have, what about a pair of Arduino boards with Xbee wireless on their backs. Just set up to to a few analog and digital IO's???
Jeff
Old 03-18-2011, 09:51 PM
Brian in PA's Avatar
I'd rather be truckin'
That control setup would be pretty cool Steve! is that a old cat pedal I spy in the background? I got a bunch of old pedal tractors, I'm trying to sell 'em. Keep up the good work!
Brian
Old 03-19-2011, 04:30 AM
Hey Steve, I'll keep my eye's open next week, for pot. style controller's. Let me know if you need info on hall effect or encoder style joystick's.
More idea's http://www.jrmerritt.com/ Later, Neil#2 aka doodlebug.
