Old 04-07-2011, 01:35 AM
steamer's Avatar
steamer steamer is offline
Default Re: Steamer
Thanks. got the frame of the trailer made and I'm installing the dump screw drive. Made it a tandem ,tandem and not a transfer like I had hoped. To much work to make another box for the FWD. Will post some pictures tomorrow.
Rob
Old 04-09-2011, 04:55 PM
Jared Jared is offline
Default Re: Steamer
Originally Posted by steamer View Post
Question. Does anyone know the length of the reach on a transfer trailer. I can't find any info on the net and there's not one around here to measure.
Thanks Rob
I never measured one but I would guess at 24 feet for an 8-axle transfer in Washington.
Old 04-11-2011, 11:47 PM
chaseracer's Avatar
Default Re: Steamer
here you go Rob had a Transfer come in today took a picture and measured the reach for you.
Old 04-12-2011, 12:57 PM
steamer's Avatar
Default Re: Steamer
Jason. Great shot! That works out to 10 1/2" for scale and looks just right between the truck and trailer. I have all the brass tubing and now just have to get cutting.
Thanks Rob
Old 04-13-2011, 01:02 AM
steamer's Avatar
Default Re: Steamer
Here's some pictures for the trailer. General view.
Greg gave me a thrust bearing that hold the blades on RC choppers.
View of the front Bogey with turn table
View of screw drive motor and slider.
Slider with lift arms
Thanks for looking Rob
Old 04-15-2011, 12:35 AM
steamer's Avatar
Default Re: Steamer
Here's a few more pictures of the trailer. Coupled the FWD on the front and it measures 63 in. front front to back.
Made up the reach and now have to solder it up and add the reach jack.
More pictures of the screw drive.
Thanks for looking.
Rob
Old 04-15-2011, 07:31 AM
Default Re: Steamer
Look's goood Rob, keep us posted!
Later, Neil#2 aka doodlebug.
Old 04-15-2011, 01:31 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Default Re: Steamer
Thanks for the photo's Rob. That really helps to understand the screw drive setup.
p.s. Looks like we are going to have to build alot of road this year just so you can get that rig turned around... hhahah
Maybe even pav esome road, that thing is loooonnnngggg...
greg
Old 04-15-2011, 03:37 PM
TheMachinist's Avatar
Default Re: Steamer
Oh that sounds like fun. An R/C paving machine
Trailer is looking really good Rob
Old 04-20-2011, 06:35 PM
steamer's Avatar
Default Re: Steamer
Well I finally got more done on the trailer.
First picture is the carrier for the dump box.
To make it roll better on the main frame I installed roller bearing with flanges.
Frame in the travel position.
Frame in the dump position.
Short vid of it lifting, the first bit is just traveling along the frame before lifting.
Old 04-20-2011, 06:47 PM
rockNmayhem's Avatar
Default Re: Steamer
Hey Rob looks like the trailer is opperating pretty smoothly. Have you figured about how much it will lift yet?
~Tyler~
RockSolidCustoms
Old 04-20-2011, 09:38 PM
steamer's Avatar
Default Re: Steamer
You Bet. Greg and Lou were here this afternoon and we put 25 lb. on it and it lifted no problem. I'm not sure how much the dump box full of dirt or sand will be, but I think it would probably be less and handle it fine.
Rob
Old 04-22-2011, 02:39 PM
steamer's Avatar
Default Re: Steamer
Finally got the reach finished with lift jack installed.
Also had a chance to get some outside shots of the FWD.
Thanks for looking.
Rob
Old 04-23-2011, 01:25 AM
RCLogger's Avatar
Default Re: Steamer
Nice work on the reach Rob, the FWD looks great. In think you are going to have to learn to run the hoe, as the bumbs who run it now will be alittle rough on your shinny rig... LOL
greg
Old 04-23-2011, 02:47 AM
texken's Avatar
texken texken is offline
texken is on a distinguished road
Default Re: Steamer
Try this link.
See how the use Transfer Truck and Trailer.
TEXKEN
Paste link in WEB site(only), will take you to the site.
Look for the Contest on right.
http://www.youtube.com/user/zpetester
They turn off Truck leave in reverse and use starter to back truck when hooking trailer up.
Old 04-23-2011, 12:50 PM
steamer's Avatar
Default Re: Steamer
That's quite the video. Those guys make it look way to easy!! Mine is not quite a transfer but it kinda looks like one. Next time around I'll build one all the way, and go for the two trailer version. Thanks to Steve, I have the high lift tailgate figured out.
Rob
Old 04-27-2011, 11:01 PM
Default Re: Steamer
The reach looks really good. What are you using for heat when soldering?
Old 04-28-2011, 01:31 AM
steamer's Avatar
Default Re: Steamer
I just used a propane torch for it all. The tubing joints were all slip fit so I used resin core solder. As the pintle block had no attach points, just cut into the square tube, I silver soldered it for strength. Turned out to be quite strong but we'll see how strong it is, after first time I jack knife it.
Rob
Old 05-08-2011, 02:35 PM
steamer's Avatar
Default Re: Steamer
Time to update some pictures. got some of the box built out of styrene.
Also decided to build the tailgate hinge from styrene and it turned out quite strong.
Trailer in travel position.
Trailer in dump position.
FWD and trailer both with boxes up.
Thanks for looking
Rob
Old 05-08-2011, 04:53 PM
Default Re: Steamer
Wow that's really looking good.
Can't wait to see it in action.
