Old 04-30-2011, 05:23 PM
J Hall J Hall is offline
J Hall is on a distinguished road
Default spring dirtwork
I got is an little time on the D8 today..
1/8 scale Radio Control D8 that is...
Old 04-30-2011, 07:51 PM
Car5858's Avatar
Car5858 Car5858 is offline
Default Re: spring dirtwork
Old 05-01-2011, 12:37 AM
will43209's Avatar
will43209 will43209 is offline
will43209 is an unknown quantity at this point
If I had one of those, I'd level my whole backyard!! But, then I'd be divorced! Hmmmmm!
Old 05-01-2011, 10:06 AM
td9clyde td9clyde is offline
Dozer Builder
looks great keep'em pushin
Old 05-01-2011, 12:15 PM
TheMachinist's Avatar
Lookin good
Old 05-01-2011, 12:17 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Love to see someones toys workin' in the dirt!! One of these days, I am going to either make or buy one of these Make????? I kind of doubt that is goin to happen
LYNN
Old 05-02-2011, 05:58 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Very good work Jerry, looks like you moved alot of dirt. Is there a loader being built next ?
greg
Old 05-02-2011, 10:10 PM
Thanks for looking in everybody...I still have undercarriage problems so I wll try to fix that as time permits..it is really fun to watch it move dirt though..
A losder would really be nice, but the price of a hydraulic pump really puts me off...I keep looking for something else that would do the job for less, but there isn't a whole lot of small pumps to choose from...Any ideas ?????
Old 05-03-2011, 07:49 AM
I have the assembly manual for the old kyosho hanomag loader.
It used screw drive for lift and dump.
later Neil#2 aka doodlebug
Old 05-03-2011, 11:34 AM
Thanks Neil..
I never thought of that..I have several small gear motor in a box that might work..Others are always available on ebay..
Old 05-03-2011, 05:24 PM
dirtpusher9's Avatar
Moderator
Jerry, I showed my dad, when he was in, your models and he said it brought back a lot memories. They are something to be very proud of. Video???
Old 05-03-2011, 05:34 PM
How did you get dry enough ground to even work in?
Old 05-03-2011, 09:51 PM
I am on top of a reallly big hill....Seriously though, we have heard of your flooding and excess rain...Our thoughts and prayers are with you..
Old 02-05-2012, 04:12 AM
bambi bambi is offline
bambi is on a distinguished road
hi doodlebug.
can you make a copy from the assembly manual for kyosho hanomag loader
kind regards
ksp
Old 02-05-2012, 02:42 PM
Hey bambi, send me a pm with your email, I'll send it after the game tonight.
Hey Jerry, Have you considered building a cable lift loader? Lot's of antique examples to copy! Cheer's, Neil.
Old 02-05-2012, 04:00 PM
Hi Neil
I haven't had a lot of time lately to think about a new project..Are you thinking about something like the old Traxcavator mounted on a D4 ??
Jerry
Old 02-06-2012, 12:44 AM
Hey Jerry, are you telepathic? LOL! Yes, that's one of them that came to mind.
Cheer's, Neil.
Old 02-07-2012, 08:56 PM
modelman modelman is offline
Nice pictures jerry-just curious, what kind of problems are you having with the undercarriage?
Old 02-08-2012, 12:33 AM
Hi Modelman
In answer to your question, the problem is in several areas..
When I joined the track links I used a 1/2 inch by 1 inch nylon spacer for the bushing and used a 1/2 inch aluminum pop rivet in from each side as a track pin..Over time the aluminum rivet eventually loosened and bent under pressure..I still need to replace all the above with 1/8" steel rod..
I made the idlers from RenShape ( a machinable material that is almost like cured Bondo)
I made the sprockets out of a rigid urethane resin and drilled out the sprocket pockets..They are not accurate as they should be ands need to be redone..
The track links are milled out of aluminum and are harder than the sprocket and idlers and have a tendacy to bite in and ride up on the idlers..The idlers should be out of metal..
I do have a couple of videos on utube of the D8 in action
here is one... http://www.youtube.com/watch?v=M2k68z-t73c
Jerry
