Military Vehicles. Trucks/Support Vehicles in here. |
Well classes are out till June, the only problem was that my HD was approaited by one of the students. Luck would have it that I backed up the drive last week. No cad drawings were lost.
Anyway, my friend Tyler came through for me on the air bags. ![]() ![]() ![]() Then I realized that I gave him the wrong measurement ![]() First the product supplied was what I asked for to within 0.004" I took a trip to the local autozone, and was able to get an end section of hose material for the air bags. As I was compairing the assemblies with the 1:1 I noticed the slight bend in the bag assembly. I cut the new material a little long in case I need to shorten them later. Then I used a dremal fine burr to resize the inside. This worked out pretty good, as I was able to get the bend in the bag assembly. Next I mounted the bag to the frame mount, and support arm. I used a 2-56 threaded rod and a nylock on the top. The bottom was secured by threading a bracket that is mounted to the support arm. The best part is that it gives me a way to adjust the height of the axle. I am very happy with Tylers work, since I am a newbee. I can't understand why these bags are not on the other trucks on this great board. Heres the pics Had to add the referance pic Last edited by Car5858; 06-04-2011 at 04:26 PM. Reason: add referance pic sp |
I installed axle 3's suspension today.
Hey Carl those bags look right at home now on your project. Sorry you had to re make the bags themselves but they look great. Can't wait to see this chassis rollin.
~Tyler~
RockSolidCustoms |
Finished installing the rear drive suspension. ![]() |
Carl that thing is going to be such a beast. What axles are you going to be running on it?
~Tyler~
RockSolidCustoms |
#26
I will have to shorten the axle shafts, byt its the challange in it. I will start making a pattern for casting the axle housings in the morning. Still don't know what to do for the front leaf springs. I want to stay close to scale, but may have to compramize. If I could find some blued 1/4" annealed spring steel, I would make them myself. I found some at McMaster Carr, that is 60$ ![]() So if ya know a supplier that will supply short lengths, I am all ears. Took this beast up to the hospitle to show my Dad, he was impressed. (first time in 53 years ![]() Now he wants out so he can turn the rims. |
#27
Fist of all let me just say your wood models are OFF THE CHAIN!!!
And this Oshkosh is going to be one amazing ride... Just like the real thing, only smaller ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
#28
Thanks, to bad I never kept one of the wooden ones for myself. Maybe the next one, but the RC bug has bitten again and it may be a while.
#29
Made the axle master patterns today. Wood sealed with thin CA, sanded and recoated 3 times.
#30
Carl,
I have been reading thru your thread and it is awesome, this truck is on my list of trucks to build once i get two others finished. What thickness aluminum are you using for your suspension brackets. I hope when I get the M26 done to start on one of these thank you for sharing. Merritt
Member of Central Plains Mini Truckers and Certified Army Nut |
#31
Merritt, the brackets and frame rails are 1/16" thick. Basiclly standard extruded alumnium cut to shape and finished with a file.
I am still learning about how to build them. So far so good, changed my mind about casting the axle housings(it would cost more that the truck itself). So now I am awaiting some flat stock alumnium. These axles are designed to use Tamiya's diff setup. Thanks for looking. Carl |
#32
Hey Carl have you thought about casting them yourself? http://www.lindsaybks.com/dgjp/djgbk/char/index.html
Later, Neil#2 aka doodlebug. |
#33
On your solid modeling; Is that done with Autocad or Solid Works? I hope I can do that kind of drawing someday. |
#34
You can get fancy by adding surface textures and rendering to get jpegs like I have posted. Then use stlout on the command line to create an stl file for export to bobcad or othere gcode generator program that you have. As for solidworks, I am not that proficent at it so far. (still Learning) |
#35
I thought about that also, just haven't located some. I will have to look in the scrap bin when I pick up my order from AAA supply. |
#36
Try your local lumber yard or plumbing supply house for banding, look around construction jobsites. The stuff is always laying around.
Later, Neil#2 aka doodlebug |
#37
Thanks Neil I will give that a try.
#38
Thanks for looking and helping out so far. My materials order came in and I will be able to make some progress now. I hope to start on the front spring assembly soon thanks to Steve for helping on that score.
#39
Made some progress
#40
![]() ![]() ![]() ![]() ..... speechless! that is amazing work. what tools were used to make that? and what is the overall length? Last edited by edwalsh18; 05-22-2011 at 02:32 AM. |
Thread Tools | |
Display Modes | |
