Old 07-07-2011, 01:39 AM
Default Re: CAT 14M Motor Grader
I'm just dumbfounded by the level of detail and exactness of the parts you machine. I feel like a broken record because all I can keep saying is 'wow'! This is one of the neatest builds I have ever seen.
Old 07-07-2011, 02:58 AM
Thank you guys again for all the compliments
Got the steering cylinders done
Old 07-07-2011, 08:19 AM
I just can't design and build as fast as you do. So So NICE! You give many of us inspiration and ideas to build. Bravo!!
Old 07-07-2011, 05:01 PM
JensR JensR is offline
Excellent, so smooth and powerful
Great how all the functions fit together in the tight space
Will be interesting to see how the steering feel is, if the stick position is proportional to steering speed and not steering position?
Old 07-07-2011, 06:35 PM
rc_farmer's Avatar
Master Builder
I am amazed at your engineering and building talent. Can't wait to see it all work together.
Giving up is not an option!!!
Rob
Old 07-08-2011, 07:52 AM
I got the blade tilt cylinder done. That´s the last cylinder for now.
I have to abort the build process for a while, because we are moving to new a house. I must start to pack my machine shop to boxes, not to mention all the rest of the house...
Luckily I´m on my summer vacation
Old 07-08-2011, 08:22 AM
kerst's Avatar
kerst kerst is offline
Looks fantastic! great workmanship!
Kerst
Old 07-08-2011, 11:14 AM
modelman modelman is offline
Great looking model! You are working really fast!
Old 07-09-2011, 03:49 AM
My trailer is slightly too short for the 14M
Old 07-09-2011, 11:51 AM
Car5858's Avatar
Car5858 Car5858 is offline
Sounds like an new project, extending the trailer.
That grader is a very nice work of art IMHO.
Old 07-09-2011, 12:08 PM
Pippoe Pippoe is offline
Pippoe is on a distinguished road
Thumbs up Re: CAT 14M Motor Grader
Another impressive build!
You guys really know your ways. WOW!!!
Great job.
Cheers
Pip
Old 08-14-2011, 02:30 AM
Hi guys, I´m finally able to get back to work with the grader after moving to a new house What a job that was it took a while to get my "machine shop" up and running.
First part I made was the front piece of the engine cover top.
Old 08-14-2011, 03:06 AM
Aussie's Avatar
Aussie Aussie is offline
Aussie is on a distinguished road
Unbelievable, Ari, Just Awesome!!!
I've never seen anything like this, Great Work, Mate
Paul
Drive it like you stole it!!
AKA Willsbrook
Old 08-14-2011, 05:26 AM
Fantastc model! Great job!
regards,
Frank
Old 08-14-2011, 01:40 PM
Straywolf's Avatar
Wow such an amazing build, would love to see some pics of your work place where you are creating this work of art. So when will you be mass producing the kits for these?
Mike
Old 08-14-2011, 04:14 PM
It's great to see you back to making progress on this fine project Ari... patiently awaiting further updates with great interest.
Old 08-19-2011, 01:08 PM
I got the engine compartment bigger top piece done. The piece is curved half of it´s lenght, and I was not sure how it´s going to bend cause it´s 5 mm thick.
I did mill grooves in the underside in the area that should curve to help it bend.
Then I band saw a wood block to the same curvature and place the aluminium piece between them. Next I put it to a hydraulic press and press the wood blocks together (plate between), but as I release the pressure the plate returned straight Then I decided to heat the aluminium plate hot and did the pressing again. I left it under pressure to cool down, and this time it did stay in correct shape
Old 08-19-2011, 01:55 PM
You don't need to make two dies. All you need is one. Take a piece of soft rubber or urethane (you can get different hardiness) Place the part on the rubber then ram the die. The rubber will conform to the die pressing the metal. This may take some practice on what hardness rubber but the end result will leave no marks on the aluminum piece. I have a long urethane die I use on my press brake that I bend painted aluminum sheet on and the die leaves no marks.
Here's a picture I found on the web of what I was describing.
Old 08-19-2011, 02:08 PM
great work on the grader Ari, bravo on the heat
Old 08-19-2011, 03:56 PM
diddys trucking's Avatar
diddys trucking diddys trucking is offline
diddys trucking is on a distinguished road
STUNING JUST STUNING you are a model enginering god we are not worthy
