Old 09-17-2011, 06:49 PM
Tamiya Cowboy's Avatar
Talking Reiks Trucking Inc.
Well time for another one of them worthless long and low working show rigs everybody loves to see . This is a rebuild of a truck I got and I have wanted to build a copy of a friend of mines truck for a while now so here we go. Now it wont be dead on but close I am going to change a few things I would change if it was mine and since he wont sell it to me Ill have to settle for this for now..
So here is the truck I am starting with..
Starting with a new frame that is shorter and one that has the ends of the rails tapered down.Now I went a little longer then his real truck but it is the same as my wife's orange truck..
Going to fast forward here a little you don't need a screw by screw build of a frame and if you do you need to use the manual..
Here is teh frame with the running gear on I have lowered the front 1/4 inch and slid the axle forward also and mounted wedico tires on stock tamiya wheels for the low pro look. Also have on of IH Builders box bumpers mounted up front..
Next to make some 5 inch long fuel tanks out of PVC Pipe..
Ends cut out and glued on.
Now if you look I too another thin piece of plastic and cut out a 5/8 inch round piece and then flattened 2 sides so it look like the fuel tank bung that is welded to the tank and then I used a stainless thumb screw for a filler cap.
Little mock up..
Ok so now body mounted and a set of Brian in PA's pete steps mounted also.
And now for mounting the new tanks.
Now some of you might be saying that way is the tank mounts kind of goofy well I needed the thickness of the mount to raise the sleeper up so they are set in the same spots as the mounting holes for the sleeper..
Now on to the body work.. Not to bad of only 6hrs of work on it..
Paul W. "Tamiya Cowboy"
Old 09-17-2011, 08:45 PM
heavy_duty's Avatar
heavy_duty heavy_duty is offline
heavy_duty is on a distinguished road
Default Re: Reiks Trucking Inc.
Great start there.I think that truck looked bad as a day cab.TC you are full of new tricks,I like the fuel tanks.
ED
Old 09-17-2011, 11:03 PM
ED
Thanks Much Ed.. Yeah it looked sweet as a day cab but it would be Project 350 Day Cab as long as it is as a day cab..
Ok one more step closer to looking like Dave's truck.. I have added the cab skirts to the cab and the sleeper..
Started with a temp-let to get the sized and shape just right..
And then out of plastic..
Then the sleeper I should of got step by step picks but it took 2hrs to get the sleeper skirts right with the tanks and all but here are some. I started with plastic angle screwed and glued to the bottom of the sleeper.
Then cut fit remove cut fit remove cut fit remove and so on and son on.. And WA LA!
More detail and body work tomorrow ..
Old 09-18-2011, 12:14 AM
BRICKNICK's Avatar
Nice job TC, I like the trick way you made the fuel cap n bung, it looks pretty close to real pete tank. Who originally put the truck together? Is that the wedico hi top from pmd on a tamiya bunk? Do you have a picture of 1:1 truck to see what your build is based off of?
Old 09-18-2011, 12:50 AM
It is a wedico sleeper with PMD stand up top on it I will be putting the stock roof back on it thou stand up wont work for this truck..
Here is the 1:1
Old 09-18-2011, 01:19 AM
nenard's Avatar
nenard nenard is offline
nenard is on a distinguished road
This rig was hot when you first got it. The upgrades will only make it sweeter!
Old 09-18-2011, 05:23 AM
ddc333 ddc333 is offline
ddc333 is on a distinguished road
Paul what was the truck before you started to change it ??
Daniel
Old 09-18-2011, 12:01 PM
sneaky-pete's Avatar
Master A-Modeler
Nice work Paul.......the tanks are cool!
Mock-up is fun.
The graphics on that 1:1 look like a challenge
Troy
Old 09-18-2011, 03:12 PM
Stepside's Avatar
Stepside Stepside is offline
Super Moderator
Nice work on the tanks, kool idea and executed well... Are you going to paint them?
East Coast Mini Truckers
Old 09-18-2011, 07:55 PM
Thanks Much Nenard if you seen the truck in person you would see up close it is a little rough around the edges but i really like and would love to own it for real..
It was the Blue truck in the first post?
Mock-up is fun.
Thanks Much Troy.. The strips wont be tuff at all Ill show them when I get to that point.
Thanks Much Rod.. After going of the truck with my very good Friend Wade "ExHood" who also knows the truck and its owner we have decided to paint the steps and the tanks the same color red as the frame it will be a cleaner look. The only reason the steps are black on the 1TO1 is they are in rough shape so he painted them..
Originally Posted by SANDCRAFT TRANSPORT View Post
Same here only half the pic have shown up, all where there yesterday
Tim
And Tim I have no clue what you are talking about but Thanks for the comment anyways..
Old 09-18-2011, 10:42 PM
DuelTruckDriver DuelTruckDriver is offline
DuelTruckDriver is on a distinguished road
Paul, Nice fuel tanks, those are spot on man! I'd never though of using pvc for that The clearences are perfect on the skirts also very percise man. D@mn does the sleeper door open?, looks like it.?. >Marty<
"You play meat?"
Old 09-19-2011, 08:06 AM
Thanks Much Marty! I am very happy with the tanks and yes the sleeper doors open it is a metal wedico sleeper..
Ok little update from late last night..
Did my drive line like I always do nothing really new there.
Also did my little trick and I think others do something similar so it steers alot better.
Then i tried to see if i could make my eyes pop out of my head and make a shuttered grill and it just about worked after a hour and a half..
Used polished stainless for the shutters I still need to clean it all up from my fingers.
Old 09-19-2011, 08:25 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Paul, Grill looks nice as does reat of the truck. ?? for you- what thickness of stainless steel did you use for the louvers in the grill?
LYNN
Old 09-19-2011, 09:55 PM
Exthood359's Avatar
Exthood359 Exthood359 is offline
Weekend Gear Jammer
Exthood359 is on a distinguished road
Member Of The Central Plains Mini Truckers..
Old 09-20-2011, 12:57 PM
Straywolf's Avatar
Wow that grill is amazing!!! Are the shutter's fixed or do they open and close? Also could we see a pic from the back side of the grill sir?
Mike
Old 09-20-2011, 09:27 PM
Lynn Not sure it is the stainless that Brian in PA sells
Originally Posted by Exthood359 View Post
Thanks Much driver.
Mike
Thanks Mike.. They are fixed I have no need for them to move and ill get you a pick later this week so check back..
Old 09-20-2011, 10:18 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
great work paul - i like those tanks - emphasises the idea of using common materials. your grill looks good too.
chris
Old 09-20-2011, 11:00 PM
Brian in PA's Avatar
I'd rather be truckin'
Great Build Paul! The detail that you are putting into it will make a great truck for sure. I like the raised area around the filler cap on the fuel tank, nice attention to detail! The grille came out nice also, its a real pain in the a$$, huh? you've captured the look for sure!
Brian
Old 09-21-2011, 09:25 PM
Straywolf's Avatar
Thanks Much driver.
Thanks Paul i will be watching and great work on the truck so far!!!
Old 09-23-2011, 05:26 PM
Roadmasters's Avatar
Moderator
Lookn good paul, Ive always wanted to do a grill like that. Is it going to be painted black like the real truck?
Arioch
