Yes ok we looked at that but thought that the cutter would give a round finish and not give the nut enough to hold onto. The way we have done it should give maximum strength. Maybe if there is any interest in the finished model the next round could have this detail, but at this stage the three machines are for us to play with.
![]() Last edited by titandigs; 10-28-2011 at 04:32 AM. |
i have a question if all those peices are the rail links how do they go together your going to have to cut more out right? on each end i may have missed that and sory if i did but keep up the great work
Yes very observant
![]() These were the first links and track plates out of the machines, so the real thing will have a better fit and look. ![]() ![]() ![]() ![]() Last edited by titandigs; 09-29-2011 at 07:17 AM. |
Will there be a bushing on the short side for the pin to pass through? I like the start of those grousers. Will you drill and tap blind holes to mount them? Put a scale next to them so we can get a feel for the size of your tracks.
If you have a look on page one, in the carboard box you will see the mounting holes for the track plates and the extra two holes are for holding the pin in place.
The track plates will be 61mm long based on a 36inch 1.1 |
#26
OPPS, I missed those holes
![]() ![]() 2.40'' wide tracks, That will look really good. Last edited by 9W Monighan; 09-29-2011 at 08:02 AM. Reason: track width |
#27
Any thought of adding a full radius keyway cutter to your 1st op on the track links so you don't have to mill the inside ends of the track links for clearance in a 2nd op?? Like I said, I have been running 4 axis Okumas for over 20 years and know a lot of short cuts!! Also, you might want to look into fine-tooth roughing cutters to hog out most of the material on the track plates. Looks like you used 1 on 1 end of a track plate??
Just some ideas ![]() ![]()
LYNN |
#28
#29
nice work i like your final peice's looks good to me
#30
Pual , the plates look good
#31
I see you said you are making 3 dozers at once. Are you planning on selling these or are they being made just for yourself?
#32
The scale is 1/15 and the three dozers will be one for me one for my nephew and the last for my brother-inlaw. Who knows if they turn out ok and there is interest a kit could be possible, but its not on the list of things to do as the time involved is huge
#33
Nice work on the links! Good to see someone that can move things along.
#34
The track plates are now all finished, so now the long job of fitting
![]() ![]() Last edited by titandigs; 10-28-2011 at 04:54 AM. |
#35
#36
I can only dream of having an Okuma to play with in my shop. Looks like you have everything well in hand
LYNN |
#37
I can only dream of having a fully equipped workshop LOL
Nice work on the machining of the tracks going to follow this build with interest and envy at the same time LOL |
#38
Those turned out really nice. Did you make the grousers one at a time or machine a longer strip then cut to proper length?
#39
Very nice, love these builds!
#40
very nice work! Inspiring!
Kerst |
