#221
I started to add the hydraulic hoses, first I install the steering related ones.
Theres going to be a lot of hoses when I´m finished ![]() ![]() ![]()
#222
I'd paint this thing before I'd plumb it, gonna be mezzy taking it all apart afterward.
![]() Will mine be ready to ship in the new year? ![]()
#223
You are right about that, but with this one I want to see that if it even works the way it should, before painting. It´s easier to do the needed modifications when you don´t have to watch out the new paint job.
#224
Looks amazing as always! About the paint, just spray it all yellow when all hoses ar installed, then go bash it!
#225
Got some more plumbing done
#226
Nice job, cant wait to see this thing move!
#227
Boy that is a lot of hose! Your doing great with routing it all, and keeping it tidy with the anchor points and hose retainers. Very clean.
Nathan |
#228
Hoses, hoses and more hoses...
#229
UNBELIEVABLE!!! Keep up the good work and keep us all posted with updates.
-Terry
FabOne NW Ohio |
#230
****!! How many meters of hose have you used so far? And all those tiny fitting mounts for the hoses, youre a mad man, in a good way!
#231
Hosing nightmare!!!!
#232
I got the hoses pretty much hidden, however the mess is at the back of the machine now.
#233
It's an incredible level of mastership that you offer to us! When I'm thinking of all the machining work, planning, designing and everything it involves, I'm speechless... Great great job! Thanks to share!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#234
Now what did you do to pair up all the hoses at the back? Tape them together...
What size tubing is it? 1.5mm throughout? |
#235
Here is a video of the 14M running first time whitout hydraulics ![]() http://www.youtube.com/user/Hemi1966#p/u/0/KG1thM-DLhc
#236
Ari,
I've been following your project, I have to say that perfection is expectable that you realize the project. Congratulations! In cutting blade you used linear guide which model was it? Thank you, Carlos |
#237
Great video! You've got to be really happy and proud of your work up to this point. This is amazing, and great to see the model moving under it's own power. The turning radius looks great, for it being so long.
Nathan |
#238
Other than tires, bolts & other miscellaneous bits, you've built everything to this point, well done Ari!
![]() Are you making your own pump & valves too?
#239
Hey awesome looking build! I have been following it since the start and it always keeps getting better! just wondering though, where did you get the tubing you used for the hydraulics?
Thanks, and keep up the sweet work! Chris |
#240
