#221
Thank you, Jonathan.
I wasn't very happy with the way that the garden shut down but there wasn't anything I could do about it.
Joe |
#222
we could shure use some new video's or pics.......................i did get to run my dozer with a radio finnally lol Travis let use his batteries and wired up both sabertooth speed controlers it was cool to see it run on it's own , now we just need to get together sometime and show these fellas we can move dirt lol
I built this thing and have it working now what do I do with it? Last edited by td9clyde; 02-04-2011 at 09:41 AM. |
#223
Thats cool you ran it so where is the vid, Henry????
Been thinking about another video. But have to wait for better weather.
Joe |
#224
hey i saw your dozer on youtube a while back and wow... i, like everyone else, didn't know it wasn't the real thing at first. really awesome! i decided to post up here after not finding what i was looking for.
i am interested in doing a D11 - 1/16th scale, i want to power it using craftsman drills. would you be able to show me how you mounted yours? did you keep the 2 speed trans (if they had them)? did you use esc or the PWM's? did u remove the gear reduction that connects the tranny to the chuck? what drill did you use? how did you mount to hub? i am anxious to finish planning this build and start building. i highly doubt mine will come close to yours but as long as it functions. i need to put it to work in my yard. any info u have will be appreciated. Thanks! |
#225
I ran it the video is on my youtube channel and on like page 16 or 17 or 18 in my thread lol
#226
I hope you do build the 11. Here is the best pick I have of the motors and how I mounted them. ![]() I used the Craftsman 19.2 motors and planetarys. Had to cut off part of the planetary housing to mount them sideways. I did use the 2 speed trany, just haven't put the servo back in it, that shifts it. I used the Sabertooth 2x25, it only draws 6.34 amps after gearing down 4 to 1 of the factory gearing on the drill motors. I tact welded the hub on. Hope some of this helps. If you need anythimg ,just ask. Sorry for the late reply.
Joe |
#227
I saw your videos on youtube, a very good machine you have here. My father is a mechanic and just built and engine for a D9 a while ago.
#228
Thank you Stewmeat, and welcome to the forum.
Joe |
#229
Rained out!!! WOOO HOOO!!!
It's been almost a year since I was able to do anything in the shop, that's entirely to long. When I first built the dozer I put a winch on it and stripped the plastic gears in it pulling my riding lawn mower. I used a planetary and motor out of a cordless screwdriver and geared down some on top of that. I've been on the net trying to find some replacement gears and the only ones I found that would fit have been discontinued. So I need some suggestions on where to find some. In the first pic you can see they have a lot of wear on them. Trying not to have to redo the whole winch, so all the help you can give would be appreciated. ![]() ![]() ![]() Here are a few specs. pitch dia. .500 # of teeth 24 pitch 48 20 degree pressure angle
Joe |
#230
#231
Steve most of the internal gears at Stock drive are out of stock and are too narrow for what Joe shows here. I tore a old air drill apart the other day and the gears in that may work here. I'll be using those gears for my planetary reductions on those RC4x4 axles I just bought.
#232
Finally ,....the guy comes back and is workin on somethin in the shop glad to see you back on here and tinkerin
#233
Well I got tired of looking for the gears, so I'm in the process of building a planetary and putting a bigger motor on it. Now just gotta wait for more time in the shop.
Joe |
#234
#235
I have the planetary built and tested for my winch, so far so good. I'm ready to wire this thing up and I want to wire it to a proportional channel but I don't have an extra one. So my question is, can I put a ''Y'' servo lead and go to the same channel that my blade works off of and set it up as a different model on my radio where all I would have to do is switch model modes? Is that possible?
Joe |
#236
Joe if you have an extra two pos switch you can use this battle switch to run two servos independently from one proportional channel. Just Y off the channel to two servos and run the signal wires through the battle switch to interrupt the signal to one or the other.
Link to switch Travis
#237
I was going to go through an ESC and trying not to put any more stuff in there then I have to. All that wiring starts running together, for me anyway. That's a cool switch though.
Joe |
#238
You can Y harness an esc off any function on the radio and set it up like I described above or you can use an existing esc and use the battle switch to switch between two motors. I used one of those switches in Doug and Travis's to use one esc to control the up and down motor and bed extend motor with one ESC. Just some thoughts.
#239
#240
Well, was messing with the dozer today and the hydraulics quit working so i checked everything out and the belt or band the connects the motor to the pump broke. So where do I find this at (Germany)?
Joe |
