Old 08-22-2011, 03:20 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Default Re: Wedico 966G Build
She comes with decals.......
Old 11-21-2011, 04:18 PM
pigeonfarmboy's Avatar
Makin a dozer blade!
Old 11-21-2011, 07:45 PM
Izzy's Avatar
Backyard enginier
Ooohhhh - snifty - is this for the coming snow fall?
Old 11-22-2011, 06:16 PM
Would definitely work for that. More so for all the dirt/sand I'm going to be dumping in my basement!!
Old 11-22-2011, 09:45 PM
You're filling your basement with dirt/sand?! And doing it thru a window with the rc's?
'at a boy!
Old 11-25-2011, 05:38 AM
Just need to mount the quick detach plate now! It's 4:45am....must have been the TURKEY POWER!!!! I think it turned out good considering I didn't have any drawings/plans. Even tacked on a consumable blade edge.
Old 11-30-2011, 02:30 AM
Front and rear driveshafts are binding bad when fully steered left and right. Completely stalls the motor when in reverse.
Anyone experience this with this model? Should I just take out the shafts and file the u-joints? Haven't been driving this **** thing long enough for driveline problems
Old 11-30-2011, 07:21 AM
do u have the pot metal u-joints or the zinc plated steel ones? I had similar issues with my 966g when the pot metal joints where used. In the hinge area plates are there chunks of brass around the pins?
Old 11-30-2011, 11:35 AM
No brass shavings and the u-joints look to be pot metal.
Old 11-30-2011, 08:27 PM
can u post a pic of the loader hinge area to help me get u the right answer to ur problem?
Old 12-01-2011, 04:00 PM
Top hinge:
There is a very slight amount of play in the hinge. Maybe a millimeter.
Driveshaft/Bottom hinge:
You can see how the u-joints are wearing on the edge of the sphere. I suspect that to be the issue. It's not limited to the front or the rear shaft either. When I disconnect one or the other it will still stall. Need a temp fix. I'll probably put some different shafts in entirely. I've always had great success with the MIP stuff. Might have to customize something to fit.
Old 12-01-2011, 04:11 PM
I'd say get rid of that shaft and get a real u joint . thats the most micky mouse joint I've seen ( no offense ) pot metal will not last long under torsional stress . is there a slider on the shaft ?
Old 12-01-2011, 05:05 PM
Izzy's Avatar
Backyard enginier
these joints are a bit on the weak side - but it does look like that joint is noy fully engaged at the ball. right side looks slightly open.
mine have held up without issue -
ive heard of guys swapping the systgem out.
Old 12-01-2011, 07:49 PM
Izzy's Avatar
Backyard enginier
Also - you need to keep that ball directly over the center of the hinge pin - so loosen the set screw on that right half and adjust.
Old 12-01-2011, 10:54 PM
upgrade to the steel zinc coated u-joints. I did that and upgraded to new plate with brass like u have already. U have some worn out pot metal u-joints. U will need to order two sets of wedico number 2017 u-joints.
Old 12-02-2011, 02:17 AM
Cool will adjust for now and get those ordered up!
Thanks gents!
Start thinking about when you guys want to bring your stuff over for some weekend mini-fun.
Old 12-02-2011, 08:15 PM
Izzy's Avatar
Backyard enginier
ya got crash space .... for us Indiana guys thats a chair to sit in for a few minute or so .... LOL
Old 12-03-2011, 02:39 PM
YoungGunz's Avatar
Well shoot, i never knew you were in monticello... i have an aunt and uncle that live there and I'm just a couple hours west..
-J.D.
Old 12-03-2011, 03:12 PM
Yup, wonder if I know them I grew up here.
I have 2 spare bedrooms a foldout couch and airbed as well. I'm 2.5 hours from Indy for reference.
Old 12-07-2011, 04:17 AM
Where can I get Leimbach parts? I broke the drive coupler off the motor somehow. I guess this loader is cursed! Should have some video by now but I've been working on this bastard non-stop.
At least I have my fellow grown-up-sandbox nerds to help
