Secondary housing with Tandem mounting flange assembly and final drive bearing housing.
![]() The two parts pressed together. ![]() |
Another view of the pressed parts.
Rear housing before final assembly.
Rear housing assemblied without the internal gears and final drive. That will come later.
Wow, another amazing build. Can't wait to see it finished.
#26
Wow nice bolting. What size are those bolts? Looks a bit challenging doing the ones with the button heads in the blind hole (unless it was done on the machining center)
#27
Wow, that´s beautiful
#28
Good grief those axle housings are phenomenal! I really don't know what else to say, except keep the updates coming, as you progress with this!
Nathan |
#29
I looked at this last night right before we headed out for dinner. The first thing that came to mind was Holy Sh!t!
What you've done so-far is truly amazing to me! Please keep the pictures and info coming! Reg |
#30
Very nice looking build.
Jeff |
#31
Wow, that´s top-class! Really inspiring. Those flanges with the ribs seems like a complicated job. How did you do them? Are you using a four- or more axis mill?
By the way, looks like you are using stainless steel. Right? Stefan |
#32
WOW, I'm astounded the craftsmanship. Way out of my league.
Joe |
#33
I wanna do inappropriate things to that axle housing :O
#34
Beautiful work!
Very inspirational. Thanks for sharing.
#35
rather interesting - Teh axel housign brings a smile and delight to most peoples faces including mine and it brings ilicit thoughts to Pigeons mind......dude your twisted LOL ...... it is beautiful though......
#36
The bolts are M2 x .4 and they were drill and tapped on a machining center. |
#37
#38
Believe it or not but these parts are all very well machined T6 –6061 Aluminum |
#39
The wheels...
#40
The wheel is pressed into the tire.
