Old 12-31-2011, 09:02 PM
mpe's Avatar
mpe mpe is offline
mpe is on a distinguished road
Default Re: MPE – 24M Motor Grader Build
Secondary housing with Tandem mounting flange assembly and final drive bearing housing.
The two parts pressed together.
Old 12-31-2011, 09:04 PM
mpe's Avatar
mpe mpe is offline
Another view of the pressed parts.
Old 12-31-2011, 09:06 PM
mpe's Avatar
mpe mpe is offline
Rear housing before final assembly.
Old 12-31-2011, 09:08 PM
mpe's Avatar
mpe mpe is offline
Rear housing assemblied without the internal gears and final drive. That will come later.
Old 12-31-2011, 09:31 PM
Wow, another amazing build. Can't wait to see it finished.
Old 12-31-2011, 10:01 PM
Wow nice bolting. What size are those bolts? Looks a bit challenging doing the ones with the button heads in the blind hole (unless it was done on the machining center)
Old 01-01-2012, 02:07 AM
Wow, that´s beautiful Will there be a chain drive to the wheels ?
Old 01-01-2012, 02:19 AM
Good grief those axle housings are phenomenal! I really don't know what else to say, except keep the updates coming, as you progress with this!
Old 01-01-2012, 10:12 AM
I looked at this last night right before we headed out for dinner. The first thing that came to mind was Holy Sh!t!
What you've done so-far is truly amazing to me! Please keep the pictures and info coming!
Reg
Old 01-01-2012, 10:50 AM
pugs pugs is offline
Very nice looking build.
Jeff
Old 01-01-2012, 12:34 PM
Stefan Stefan is offline
Stefan is on a distinguished road
Wow, that´s top-class! Really inspiring. Those flanges with the ribs seems like a complicated job. How did you do them? Are you using a four- or more axis mill?
By the way, looks like you are using stainless steel. Right?
Stefan
Old 01-01-2012, 06:05 PM
dirtpusher9's Avatar
Moderator
WOW, I'm astounded the craftsmanship. Way out of my league.
Old 01-01-2012, 06:28 PM
pigeonfarmboy's Avatar
I wanna do inappropriate things to that axle housing :O
Old 01-01-2012, 06:58 PM
SmallHaul's Avatar
Beautiful work!
Very inspirational.
Thanks for sharing.
Scott
"No load is too Small"
Old 01-01-2012, 09:46 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
rather interesting - Teh axel housign brings a smile and delight to most peoples faces including mine and it brings ilicit thoughts to Pigeons mind......dude your twisted LOL ...... it is beautiful though......
Old 01-01-2012, 11:57 PM
mpe's Avatar
mpe mpe is offline
Thanks.
The bolts are M2 x .4 and they were drill and tapped on a machining center.
Old 01-02-2012, 12:11 AM
mpe's Avatar
mpe mpe is offline
Yes I am using a chain drive for the wheels. Take a look at this...
Old 01-02-2012, 12:34 AM
mpe's Avatar
mpe mpe is offline
Stefan
Thanks Stefan. The ribs were a problem from the start. It took a long time to find bearings that would fit in the overall design and when I did find the ones that I am using now (Two - 40 x 50 x 6mm), I could not find a place that had any in stock. The design was challenging enough but trying to find a shop to machine them for me was not easy either. When I finally got the parts machined ( on a 5 axis machine)– the shop miss-read the drawing and drilled and tapped the blind holes into the rib pockets. I had to fight to get them to remake the parts for me per the drawing. As you can see I won the fight and the part looks great!
Believe it or not but these parts are all very well machined T6 –6061 Aluminum
Old 01-02-2012, 12:37 AM
mpe's Avatar
mpe mpe is offline
The wheels...
Old 01-02-2012, 12:38 AM
mpe's Avatar
mpe mpe is offline
The wheel is pressed into the tire.
