Old 01-14-2012, 10:11 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default SW K100
I am epically slow builder. This project mostly sits in boxes, rather than on the workbench.
Nothing special about the chassis. Not sure I like the 4:1 so it will probably go in favor of pinion reduction.
First order of business was to get headlights. My K100 is later model, lets say 1992.
Next was the axle and lower cab "wheelwell"
I need some more clearance on the wheel so may have re-bend the spring a bit more or add spacer.
Filling the rear panel:
I think I may redo the rear cutout. One problem is I think its a little low. And second I bought a set of S&P sweet pipes that are so big they won't fit/hide under the short side skirts. The entire bottom edge may have to move up 1/4" or so. Not sure how I'm going to solve that one.
Starting work on the side:
Not much progress for the two years I've had it.
Old 01-14-2012, 10:47 AM
Pippoe Pippoe is offline
Pippoe is on a distinguished road
Thumbs up Re: SW K100
Great! Another K100. ..and looking great too.
Looking forward to seeing more pictures.
*thumbs up*
Cheers
Pip
Old 01-14-2012, 03:06 PM
SWAGGER's Avatar
SWAGGER SWAGGER is offline
Default Re: SW K100
Nice work, once you get some momentum going you'll be be flying.
Old 01-14-2012, 07:33 PM
Default Re: SW K100
I love what you've done so far. Keep us posted, I like KW's.
Old 01-14-2012, 08:43 PM
1985 kenworth's Avatar
Cool Re: SW K100
gotta love the kws i was thinking of doing one with the square lights too i will be watching this one for sure
Old 01-14-2012, 10:39 PM
Default Re: SW K100
That looks good to me! I like seeing more and more of these Globeliners converted to KWs. I'd say you're no slower of a builder then I am. I've been working on the same truck for way to long. Is it five years now? Ugh. But not steady. That's my excuse.
Old 01-15-2012, 10:07 AM
CustomClod CustomClod is offline
CustomClod is on a distinguished road
Default Re: SW K100
Looking good so far. Keep it up
Scott
I run a single stack Mack with a dump body on the back!
Old 01-15-2012, 04:17 PM
Crossy's Avatar
Crossy Crossy is offline
Crossy is on a distinguished road
Default Re: SW K100
Great Job . I like it :-)
Old 01-15-2012, 10:16 PM
Default Re: SW K100
Thank for the nice comments.
I decided I don't like the tamiya floor:
Still have to cut room for the transmission and no idea where I'm going to put the battery.
Snug fit in the cab:
Then while watching GB lose I cut out the driver's door:
Old 01-15-2012, 10:20 PM
Default Re: SW K100
Looking good there, I like the new floor and you did a great job cutting the door out. How do you plan on hinging the door?
Travis
Old 01-15-2012, 10:24 PM
Default Re: SW K100
Travis
Got any piano hinges with 1/16 barrel? lol. Not sure which way I'm going to go yet.
Old 01-15-2012, 10:29 PM
Default Re: SW K100
Well your going to have to suck it up, turn in your man card and go look in the doll house section of the craft shops. In all honesty a guy at work built his daughter a doll house and it is amazing the stuff they have to build them with.
Travis
Old 01-15-2012, 10:31 PM
Default Re: SW K100
Travis
I already get Miniatures catalog (I think Micromark sold my info) and there's a dollhouse construction supply not far from my house, but they don't have piano hinges.
Old 01-15-2012, 10:43 PM
sgt hopkins's Avatar
sgt hopkins sgt hopkins is offline
sgt hopkins is on a distinguished road
Default Re: SW K100
Good looking rig! Im a GB fan so I wasn't likeing the loss..... great job on the door, did you cut it with a hobby knife?
Anybody who runs is a VC, anybody who stands still.. is a well diciplined VC!! GET SOME!
Old 01-16-2012, 07:13 PM
Default Re: SW K100
No. I used thread. Just takes a lot of time. Super thin kerf though.
Old 01-16-2012, 07:56 PM
Default Re: SW K100
Rgr... that was my next question... I used thread to bob a hilux body once.. took a bit of time yes.. anyway. good looking build..
Old 01-16-2012, 08:05 PM
Default Re: SW K100
good luck on the piano hinge I could find them either let alone in aluminum for my locker box , So , I guess I got to make , just when truck is looking great Matt . It'll look better soon
Old 01-16-2012, 08:52 PM
Brian in PA's Avatar
I'd rather be truckin'
Default Re: SW K100
Looks great so far, and nice job on the door cut!
Brian
Old 01-17-2012, 10:21 PM
Timmy Timmy is offline
Timmy is on a distinguished road
Default Re: SW K100
Hinges are a pain in the a&@, I made a set using 1/16 brass rod and 5/64 tube on mine, I just couldn't figure out an access problem for my pin. So after a suggestion by ihbuilder, I ended ip with 2 small 3/4 inch brass hinges from the hardware store stacked, take a look at my pete thread or ihbuilders to see if that would work for you.
Love the way the truck is looking
Tim
Old 01-18-2012, 12:38 PM
Default Re: SW K100
Man, you guys who can cut with thread. I can't even get it started. It just breaks. This is looking really good! I'm looking forward to seeing what's next. Very nice work so far.
