Looks great Sven.....I love the hood detail!
Troy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
yes love the bowtie visor and the hub covers
I second that! It looks like its molded in the plastic
Brian RIP FreddyGearDrive 2-12-59/12-19-11 |
Hello
![]() ![]() Thank you for the nice compliments. ![]() @glorydays24 Thank you. Yes, the sun visor, I myself have built. Have you made of plastic. There is a lot of sanding and filling. ![]() ![]() ![]() @Bsorenson79 The rear hubs are from Verkerk Modelbow. Here is the link to it. click me @Brian in PA Thank you. The caps I made of plastic details. I have removed the original strip on the hood and ground down the middle. The new detail is produced on a 0.5 mm thick and 14mm wide strips. The 5 bars to 1 mm wide and are each 1mm apart and 0.5 mm high. Left and right to remain still for the 2.5 mm rivets strips. The rivets are made of brass and have a head of 1.6 mm. It went with me now a little further. Unfortunately, one has to work only limited time to tinker. ![]() First, my good friend my new air filter was filmed on a lathe. Are you fully made of aluminum material. The hoses for that I'm bent out of plastic pipe and O-rings drawn. The entire tube was then subsequently Covered with black shrink tubing. The new fuel tank, I made tanks from the old orginal Tamiya. I removed the first thing the Chrome and have fixed glued the end caps. Everything was Stuffed several times and ground. The new tank straps are fixed by the company and keep the Wedico tanks to the frame. When Sleeper I built a new rear wall. She is also the result of plastic and was grounded after the fitting several times and leveled. The rivets are the same as from the hood. You have a head diameter of 1.6 mm. Also have 2 handles and 4 beautiful taillights found your place on the back wall. Now, there are first pictures Greetings Sven
our page on facebook " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " Last edited by Crossy; 02-05-2012 at 04:21 PM. |
Hi Sven,
it looks good, I love the fuel tanks Günther ![]()
Günther To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. from Lübeck, Germany |
#26
VERY Realistic, when this is painted, the right angle and perspective in a photo could really fool people into thinking that this is a 1:1. Nice!
Never judge a man until you have walked a mile in his shoes. Then, when you judge him, you are a mile away and you have his shoes! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#27
Looking great! X2 on the fuel tanks!
"If you build it, they will come" East Coast Mini Truckers To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#28
#29
Nice back, simple and efficiant. Good job with the rivets.
![]() I would think about the backlight to bring it up the top. @ Bsorenson79: I cn help - you will get them in a german shop: http://www.fechtner-modellbau.de/shop/index.html Regards Günther
Günther To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. from Lübeck, Germany Last edited by gungunhl; 02-10-2012 at 04:18 AM. |
#30
Sven,
That is a beautiful truck the white and chrome realy set that truck off. Simple but very beautiful like that truck alot good job. Tony |
#31
Sven, The tanks look Stupendous!! Great Job! You really make that White truck and Eye catcher. You have any plans for Lights? I can't wait to see what you come up with next!!
ECMT Members: Join your Group. Go to your username in the top right corner of the page and click on it. When your profile opens go down to group memberships, Click on East Coast Mini Truckers, The social group will open and scroll down And in the middle it you will see "Join Group" Click on it and then confirm that you REALLY wanna join. [SIZE="2"] |
#32
Hello people
![]() ![]() ![]() Many Thanks for the nice replies. ![]() It was, unfortunately, at present reluctant to continue with the build, because I was able to experience an eternal up and down with my girlfriend. ![]() I started by the drive shaft through an industrial drive shaft replaced from silver steel. The new tires from the company Modelbouw Verkerk of the Netherlands have a really good mix A small rubber tip I'd say. The lettering on the tires, I've repainted with white paint to make it look sporty. The new rear fender, I made a double fender made '. I had him cut up the middle and the rest filed. The result are the copies to be seen. The owners are also their own production. The black color only Kontrpll paint is because I made the roof. The truck is painted soon. ![]() Now there are pictures of the first current truck. Here I have some pictures of the model from North Neumünster in Schleswig-Holstein. ![]() ![]() ![]() Now for the painting. I've presented this painting. Only the Mint green is replaced with a Candy Blue. the frame is also in Candy Blue. He will get a blue underbody lighting on the sides and plenty of yellow LEDs. There is still much to do. http://www.hankstruckpictures.com/pi...9_dsc_7699.jpg Ideas about ideas, criticism, new, or something else has to do with the topic, joy I am. Greetings Sven
our page on facebook " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " Last edited by Crossy; 03-14-2012 at 03:35 PM. |
#33
You really do some great work Sven. Well done!
If I may suggest, without causing offence; use Google translator: http://translate.google.com/ It will work much better for you. Whatever you are using at the moment does not work very well, it's hard to understand what you are saying. Servus, Steve.
#34
but the pictures are great and hope you post more for us to see the rest of build |
#35
Looks soo freaking amazing, now I wanna stretch mine.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. If you got it, a Trucker brought it.... |
#36
I really like those rivets. For anyone trying to model a Peterbilt like this, they really make all the difference in the world! It's one of the best detail touches I think anyone could add. Great looking truck.
Nathan |
#37
Good morning
![]() ![]() Thanks for the nice answers. You are great Apology for my bad English ![]() ![]() Greeting Sven
our page on facebook " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " |
#38
Great looking rig... I dont really know what to say though. It all looks good, the rivets, the visor, the hood detail, the fenders, even the shrink tube idea is awesome. Good job!
I guess I did know what to say ![]()
Anybody who runs is a VC, anybody who stands still.. is a well diciplined VC!! GET SOME! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#39
Freundlichen Grüßen Steve.
#40
Very nice build Sven, That is a real eyecatcher!!
![]() Tim |
Thread Tools | |
Display Modes | |
