#461
Ooooooh, I know
![]() ![]() ![]() ![]() ![]() Cheer's, Neil. |
#462
Whatever it is it'll have to wait, Number 1 is in dire need of attention!
![]() ![]() ![]() Pump started getting noisy last wkend, the bearing in this support is toast! ![]() The whole top end here needs a bath! Tear it all down, clean it, shorten wires and mount electronics permanent, I got it working the way I want it to. Got to fit everything better so I can get the hood to sit flush. ![]() Got a mountain of dirt to clear away! ![]() I was hoping to get all the way across with this 6 inch cut before leaving the wall, but the right track went dead, a set screw somewhere in the powertrain lost its grip! I did make a movie crippling it down with one functional track, but I didn't position the lighting correctly & the dark shadows make some it hard to see. ![]() ![]()
#463
Bummer on the breakdown, hope you get it back up and digging soon!
I've moved full size hoes with a dead track, not fun at all. Cheer's, Neil. |
#464
Elliot. |
#465
I'm guessing an articulated dump truck as well. Those made by Fumotec are really nice.
Nathan |
#466
Took about an hour to strip it down.. my hands are black!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I sent Frank a mail for his thoughts.. (funny guy ![]() "Congratulations, i´m 100% shure that your model is the first that move 4 cubic of such a hard clay, normaly people just “play” with ther models. And congratulations as whell, youre the first that gets the pump unit fall in pieces, your my product tester! No, just joking a bit, it´s really interesting for me, what can happens if you really use the machine." The bit of good luck with the 1 box arriving Friday is that it has another pump assembly in it, I can rob the bearings from it and get my hoe back together in a couple hrs. ![]() Here's a part 1 of descending off the wall last night. http://www.youtube.com/watch?v=I7b4z106dC8
#467
Hi, I have a quick question. I have the same Ex. and I see that your swing motor set-up is different them mine. I have a geared motor with a wormdrive on it to run the swing gear. Yours has a geared motor directly running the swing gear. Is this the way your Ex came or is this something you changed yourself? I ask because with the worm set-up I have, when the hoe is off level at all, the swing is not smooth. It just is not that good of a set-up. I though about running a set-up like you have. Thanks, Chad
#468
Hey Joe, is there room to "double up" the outboard support bearing on the pump??? Just curious as usual.
Chad, Joe did change the swing motor, I think it's mentioned, earlier in this thread. Not sure which page? Cheer's, Neil. |
#469
Wow, you really destroyed that bearing! I kind of wonder what caused the failure. Dirt, to much tension on the belt, or maybe just plain wore it out? If dirt was the case, maybe a rubber sealed bearing would be better? I'd hate to say run a bushing instead, but I don't think you'd wear one of those out so quick.
Nathan |
#470
cbazq271, I had a terrible time with my swing drive.. there's a proper way to set up a worm drive system & I didn't know it at the time.. I tried afterward, but I think I ruined my gears already & couldn't get it to work anyway.
Frank had this prototype vertical direct mount that he sent me to try & that solved all my violent pulsating problems. PFB complained of the same problem and his hoe was built by Vario.. With my latest goodies from Fumotec I got three of these vertical swing drives for my fellow hobbyists in north america who have one of these Vario 850's.. it requires some machining on your part, the output shaft of the vertical motor is smaller diameter than the pinion gear and too short as well. You will have to make a steel bushing/longer shaft to connect pinion directly on motor. PFB is welcome to one, you can have one cbazq and one left yet. They cost me 45 euro, you can PP me $60usd + shipping, PM me your address. I'll get it out to you next week sometime. I think my problem with that bearing on the pump Neil & Nathan is perhaps the bearing slipped out of place a wee bit & was rubbing on the belt pulley.. friction = heat -> cooked the bearing. I lock-tite the new bearing in place and shimmed the support plate out a bit too. 850 is back together and working fine. ![]()
#471
Hey Joe, now the hoe is all sorted... whats in the box
Elliot. |
#472
Joe that swing seems to work a lot better. I watch your video and the way you were setting my machine would not work. It did it at the show in York Pa. I have not done anything with it sense then but I am going to change the lines over the stick and put new shafts in the drive units with screw in pins were the set screws are then they can't turn unless they brake the pins. Ed
#473
You don't need new shafts Ed, just machine flat spots where your set screws grip. Drilling a hole for a set screw pin might weaken the shafts to twist off/break at the holes.
Here's pic showing the hole I had to cut in the 850 body b/c the vertical mount motor being too tall. ![]() I'll get you some more pics tomorrow or Sunday for you to tilt your head & wonder Elliot. ![]() ![]()
#474
Joe , whats the thickness of the main structure plate , 3mm or 4mm ? Just curious
#475
Glad to hear it's fixed! Gotta luv that Locktite stuff!
Cheer's, Neil. |
#476
5mm thickness Steve.
#477
Yes please Joe, you gave us that little teaser and then you've gone on cold on me! ![]()
Elliot. |
#478
thank you Joe
#479
Did Nathan bring out his 850 for you to run too Steve? Or is the JD controls beyond your realm of thinking?
![]() ![]() This is what I built today Elliot from pre cut pieces Frank sent me.. ![]() ![]() ![]() ![]()
#480
Awesome! Looks like your regular bucket needs another coat of paint!
RIP FGD 12-19-11 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Currently Active Users Viewing This Thread: 15 (0 members and 15 guests) | |
Thread Tools | |
Display Modes | |
