#121
Oh and thanks
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Mike "DREAMWEAVER" Johnson To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. RIP FreddyGearDrive 2-12-59/12-19-11 Rims and Tanks by ihbuilder / Grill and Visor by Brian in PA / Mirrors, Front and Rear Bumper, Back of Cab Lights, and Steering Arms by tc1cat / Fenders by Stylin n Profilin / Frame Rails by The Late Freddy Gear Drive |
#122
So that's how you finish a truck ! No wonder I can't get my done my OCD or ADD keeps getting in the way of look at that spider on the wall
SHANE... Member of the Central Plains Mini Truckers.. |
#123
This thing is just INSANE! Huge and very detailed, with some awesome touches. Great work, I can't wait to see this finished. Sorry if you have already mentioned this, I couldn't see, but do you have a paint/color scheme in mind? I suppose it will need to be something pretty epic in order to finish off an epic build.
Never judge a man until you have walked a mile in his shoes. Then, when you judge him, you are a mile away and you have his shoes! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#124
Thanks Swag... Check out the first page of the build, there you will find drawings of the truck with the color scheme.
#125
Oooohhhhh man! What an amazing looking truck.
It's a beauty! ~ Jeff |
#126
Wow Mike that is one serious stage coach......that is one serious project, especially since I've been following it since the drawn up plans of the build. It's nice to see her progress this far. You are a true craftsman, not to mention with the patience of a saint, guess that's why your truck looks as good as it does and mine....well let's just say patience isn't my strong suit. Great build man.
#127
my friend that is a seriously long tractor and in all my time of building trucks and what i have seen over the years i have never seen a build as detailed as your truck...my hat is off to you ...you have done an amazing job!!!!!
#128
Thanks. And I cut it down by 5 inches..
#129
![]() ![]() I got my Bending Machine from Micro Mark this week so I got my tank straps made with the Stainless Strips from Brian. ![]()
#130
Anyone got a tissue?....drooling here! Tanks and straps are so scale....love it.
#131
****... it's gonna have more LED's than a small town. Awesome work
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. If you got it, a Trucker brought it.... |
#132
Ok brain picking time...
Anyone familiar with RC air craft? I need a cable to operate my fifth wheel release. I was thinking that maybe RC air planes use them. Here is what I am looking for only I need it much smaller and shorter. If I can't find one of these small enough then I could use some braided cable in a piece of stainless tubing if I can find it small enough. I think .018" cable would be perfect.
#133
Mike, that is a good idea, and I was thinking the same thing. But i'm like you...no luck finding aircraft cable short enough. So I was thinking of going to a local music store and looking at guitar strings. Cutting to length, bending the ends like I need them. If this works, i'll let you know.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
#134
Dreamweaver, I used to build RC planes, many years ago. Things may have changed, but I used to get delron or PVC flexi tubes in RC plane shops. This was able to take a decent curve. I would run from cockpit to tail, down inside the fuselage. I would then get a thin flexi rod to feed through the tube and then you would have screw on "horns" hand screwed onto the ends of the rods and they would snap to the servo horn on one end and the control surface (rudder, aileron or elevator etc). I am sure that this would work for you and there are choices of design and finish on the horns available.
You can also make "hard" push rods. See video below, he uses the plastic horns I mentioned, you can also get alloy ones. http://www.youtube.com/watch?v=3raUcsSjvhs
Never judge a man until you have walked a mile in his shoes. Then, when you judge him, you are a mile away and you have his shoes! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by SWAGGER; 03-11-2012 at 09:17 AM. |
#135
I do a lot of R.C. boat building, at least half of them use flexi shaft for rudder steering, I'm sorry, I can't upload pictures,for some reason it never works from my computer,but if you have access to rc boats, you'll see right away how simple it is.
P.S. Love your build. |
#136
Mike I just used a simple push rod made similar to what Swagger was talking about with a ball joint on the other end and a few other bends to get thought the turn table base plate and covered in black heat shrink connected to a micro servo...
RIP FreddyGearDrive 2-12-59/12-19-11 Love my Kenworths To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#137
![]() ![]() I was thinking hooking it to the bolt that the spring is on there so that the servo pulls to open.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Mike "DREAMWEAVER" Johnson To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. RIP FreddyGearDrive 2-12-59/12-19-11 Rims and Tanks by ihbuilder / Grill and Visor by Brian in PA / Mirrors, Front and Rear Bumper, Back of Cab Lights, and Steering Arms by tc1cat / Fenders by Stylin n Profilin / Frame Rails by The Late Freddy Gear Drive Last edited by Dreamweaver; 03-11-2012 at 06:08 PM. |
#138
Looks good Mike! the tank straps are off the hook!!
Brian RIP FreddyGearDrive 2-12-59/12-19-11 |
#139
Mike here is a couple of quick pic's till I can get her opened up , but the push rod has two Z on ether end one has a ball join going thought the turn table base plate to the locking arm and then the other end with a z on it goes thought a servo horn ( note the push rod runs under the cross member/s not through them), the micro servo is running parallel to the chassis with a adaptor plate I made to suit the location of the mount.. (I have my servo under the sleeper to keep the back nice and clean)
#140
I just took few snap shots of the rudder and servo links,but as usual it failed to upload.If you want you can Email me and I'll send you the pictures.IAMJACKIAM@HOTMAIL.CA. Jack
Thread Tools | |
Display Modes | |
