Old 04-16-2012, 09:49 PM
Joat Joat is offline
Joat is on a distinguished road
Default Where to get longer frame rails that are drilled and tapped?
Newb here and I need some longer frame rails for a king hauler , I really dont want to drill a new frame,I dont mind tapping ,but if there's a 100+ holes to drill, I'll pass, especially if someone has cnc drilled frame rails for sale?
T.I.A
Old 04-17-2012, 04:04 AM
Smiley's Avatar
Smiley Smiley is offline
Smiley is on a distinguished road
Default Re: Where to get longer frame rails that are drilled and tapped?
Ya mite can try gardentricking.com and talk yo Mr. Ric
Keith
Old 04-17-2012, 05:05 AM
1985 kenworth's Avatar
hey smiley will ric predrill them i have never seen it offered on the site
Old 04-17-2012, 05:20 AM
Smiley's Avatar
I'm not positive but it don't hurt to ask :-). I'm sure he would for a small fee :-). But don't quote me on that lol
Old 04-17-2012, 06:59 AM
"someone has cnc drilled frame rails for sale?"
I'm confused Why would they need to be cnc drilled ? It's not that hard of a job to use your stock frame rails as a pattern . Thats how most do it that offer pre-drilled frame rails .
Old 04-17-2012, 02:15 PM
ryman's Avatar
ryman ryman is offline
ryman is on a distinguished road
gardentrucking has frame rail extenions you can buy and cut your frame and install them and only have to drill 16 holes
Riley
Old 04-17-2012, 05:50 PM
REV73 REV73 is offline
REV73 is on a distinguished road
I think that what Joat, (and myself) would like to see is a longer set that is ready to use, rather than run the risk that we might accidentally butcher our original KH frame rails and have to start over with a new set. I may be putting words in his mouth but that's what I would like to be able to purchase.
Old 05-06-2012, 03:35 AM
You are correct, and I am suprised no one offers them cnc'd in like +4",+5" etc.
Old 05-10-2012, 05:36 PM
I've begun the process of getting them in from Germany, 282 views and really havent gotten anywhere with this.
Was quoted $60 a pair shipped for 39inch rails,at least I will be getting the exact samething from tamiya
Old 05-10-2012, 06:08 PM
I understand what you want but here is the issue. You have to make a lot of sets of each length to make them cost effective. Then comes the problem of a lot of builders use custom steps and tanks or the use a different suspension, then they would be left with a lot of extra holes which is what most are trying to get rid of in the first place. I just don't see enough builders stretching a stock truck. This is why blank frame rails are offered.
You have stock rails so using them as a template to drill is not that hard just use one rail clamp it to the new rail and use the current holes to drill the new holes. The only holes that will be a bit tricky are the cab mount, trans mount, and fifth wheel holes. For these drill a corresponding hole through the opposite flange on the stock rail so you can sit the stock rail on top of the new one and now you have two holes to go through which will just make it easier to keep them strait like the holes for the steps and tanks.
After you drill one rail use the new rail you just drilled clamped to the other new rail so both will be exactly the same. The only holes that cant be transferred from the first rail are the cab mount, trans mount, and fifth wheel holes but you can use the stock rail you used the first time.
Use bees wax to lubricate your tap and put the tap in your cordless drill and you can tap a lot of holes real fast.
Travis
Old 05-10-2012, 06:16 PM
Travis
I understand that, setup is not that bad, I guess there isnt alot of diy cnc'ers here, even then there no help on finding rails, Just PMD?, and the reviews are mixed with the rails themselves or customer service ,not just from PMD?and even then not many sources.
I thank you for the tips, since I have a mill,I plan on making a jig to allow me to hold the rails and not damage them and just center punch all the holes in a certain plane and keep moving on.
Old 05-10-2012, 06:22 PM
If you have a mil why don't you make a set of rails? You can get rectangle aluminum stock and mill it to shape.
Travis
Old 05-10-2012, 06:29 PM
Travis
It's not that large,and even then I dont have the time to do it, I thought about it , about $50 for material 36" of 7075 -I dont care for 6061
Old 05-10-2012, 10:52 PM
( not to be a bleep ) ,I prob. have the biggest mill on this forum with maybe 1 or 2 exceptions . the 1 that is running will only do 25" the other 30" ( on the x) to be totally honest , for what the going price of frame rails , it's not worth my time . For the time it takes to program , setup and punch a set of rails , I've done 2 by hand . I'll be making a set for myself in the future , off the top of my head , it'll be 2 hrs at least just for 1 set which from front axle back will not match anything tamiya or wedico . Whats wrong with 6060 ? I have no probs with yet . it's not the gummiest stuff I've machined
Old 05-10-2012, 11:11 PM
I cant even get blank frame rails, let alone predrilled ones? Plus I am not even sure how close the pmd ones are to stock ones? So I went and started the process of getting OE blank ones from carson,yes I did search thru all 8+ pages in this section.
As for 6061, I got spoiled milling 7075, I love how clean it mills compared to 6061, I dont have coolant on my mini mill
Old 05-16-2012, 02:36 PM
Stuart's Avatar
Stuart Stuart is offline
I've used the carson ones on my Merc 4x4, http://www.rctruckandconstruction.co...ead.php?t=4321
The're an exact match for Tamiya and come in 1m lengths for around 20 euros a pair.
Stu
Old 05-16-2012, 03:40 PM
Stu
Thanks, I found out about the Carson rails, they are the OE tamiya ones,finding someone willing to ship to the USA without asking for a kidney has been the real issue, but I found someone and just waiting for their order to come in to give me the invoice for shipping.
Old 05-24-2012, 01:34 AM
fireguard62b's Avatar
fireguard62b fireguard62b is offline
fireguard62b is on a distinguished road
I too am looking for long frames drilled to accomodate a special model. but as this would be my first RC truck I don't have any frames to take measurements off.
Old 06-18-2012, 05:52 PM
From Germany to the UK, to the 50th
Finally can start a build !!!
Old 06-20-2012, 08:13 PM
Tamiya Cowboy's Avatar
The ones from PMD match the stock Tamiya ones perfect Ric makes his the same way I make mine you could of save alot of money by paying attention to the guys that said ask Ric.
As for doing pre drilled rails for guys I have done it for people and it is a pain the trucks always have custom parts on them that you have to line up as you build that is part of building a custom truck they just dont bolt together..
Paul W. "Tamiya Cowboy"
