Old 05-26-2012, 06:43 AM
kaipi0070 kaipi0070 is offline
kaipi0070 is on a distinguished road
Default Rebuilding a used Mercedes 1850
Hey guys,
well, after a long absence I want to show you my latest model.
Just for fun I bidded on a used Mercedes 1838 on EBay. Didn´t think of getting it, but.........
After a few days, I got a box. After opening I found this:
As you can see, there´s some parts missing, like the fenders and the sunshield, but the guy who sold mentioned that, so that´s ok!
Before I started to take it apart, I did a little testrun......
The gearbox sounded somehow strange, so I opened it first.
This was horrible:
All those of you that have build a Tamiya-Truck once know, what the blue stuff is....
So I took the gearbox completely apart, cleaned it and put some grease on it, now it´s fine again.
The rest of the Truck needed a close inspection after I found this. Ther guy who built this one had no clue or simply didn´t use/read/understand the construction manual!!
Most of the screws where wrong (short one needed, long ones used), etc!!
After i corrected all this, I started to put the Merc back together, giving him some new parts, like a Poison Truck Motor, new speed controller, wide rims and tires.
I decided to paint it in a dark red, the color of a local company, specialized on heavy-weight transports.
Finally it looks like this:
Old 05-26-2012, 06:58 AM
Default Re: Rebuilding a used Mercedes 1850
NICE rebuild very nice!!
Old 05-26-2012, 11:51 AM
Diesel Demond's Avatar
that has got to be one happy little truck after all the mistakes. looks very good as its new look of life great job!
Old 05-26-2012, 06:03 PM
SWAGGER's Avatar
SWAGGER SWAGGER is offline
A touch of class, great rebuild. Nice to see an abused truck go to a caring home.
Old 05-27-2012, 02:38 AM
dabears's Avatar
dabears dabears is offline
great rebuild!!
Old 05-27-2012, 05:40 AM
Ogar Ogar is offline
Ogar is on a distinguished road
It looks good,very nice.
The lock tight in the tranny scared me yikes.
Paul
Old 05-31-2012, 05:48 AM
Did some more details on the Truck. First, I hided the wiring in the cabin, so this looks much better now:
http://imageshack.us/photo/my-images...1050494g.jpg/][/URL][/IMG]
Then I put a Poison Truck motor in and re-installed the gearbox. The guy who build this one first overturned the schrew in the pinion-gear that bad, that I had to drill a new hole and cut new windings!
But even after overhauling the gears, they still "sing" very loud. I guess, the only solution will be in changing all the gears some time!
Old 05-31-2012, 05:51 AM
And now the other Tractors came to say "Welcome to the fleet"
http://imageshack.us/photo/my-images...1050437t.jpg/][/URL][/IMG]
Old 05-31-2012, 06:12 AM
rcman rcman is offline
rcman is on a distinguished road
very nice fleet you have there! love the 1838 makes me want to build mine! I have all the parts sitting but no tranny yet!
Old 05-31-2012, 07:30 AM
Brel's Avatar
Brel Brel is offline
nice work on the rebuild of the Mercedes truck
Old 06-01-2012, 06:41 AM
coligny coligny is offline
coligny is on a distinguished road
Nice work... do you have any tips/advice on how to make clean rectangular holes for the sidemarker leds on the fenders ?
Old 06-01-2012, 11:11 AM
Hello coligny,
first I drilled a small hole with a 0,1mm driller. Then I used this one to cut the material away. After that I used a very fine file to finish the hole. I used some of the yellow squre rear-lights from Tamiya and cut matching pieces out. Finally, I glued some SMD-Led´s with 5 minute-epoxy in the inside of the fender.
I hope, this helps!
Old 06-01-2012, 04:24 PM
very nice fleet mines in shambles but should have pics by 3rd week in july
Old 06-04-2012, 07:57 AM
Originally Posted by kaipi0070 View Post
Hello coligny,
I hope, this helps!
Ok thanks, I will try that ASAP... I now have quite a stock of rectangular leds (2x5mm) to put to good use...
