Old 07-05-2012, 03:24 PM
Default 13 ft disc for my DA9190 and MF1155
Hi together!
To have some equipment for the tillage I started with a 13ft disc today. Here are the first parts....nearly 2" diameter concaved steel discs...
They will be assembled with some tubes and a threaded rod.
regards
Frank
regards,
Frank
Old 07-05-2012, 03:26 PM
Default Re: 13 ft disc for my DA9190 and MF1155
...I do not build a certain type of disc, but I hope it will look a bit like this when it´s finished...:
http://www.flaman.com/agriculture/im...hek2Offset.jpg
regards,
Frank
Old 07-05-2012, 07:31 PM
Tamiya Cowboy's Avatar
That is a nice Disc Frank there is a guy here in the US that goes to the toy shows that has built that very same one to a T very nice unit. Cant wait to see more by the way were did you get the concave disc's made.
Paul W. "Tamiya Cowboy"
Old 07-05-2012, 09:43 PM
I am also interested in where the discs came from or where/how they were made. I want to make a disc for my JD
Old 07-05-2012, 11:03 PM
If you need and are interested, I found this on Ebay:
http://www.ebay.com/itm/JOHN-DEERE-D...item4d02483471
-RCT
WCMT Director -
Old 07-06-2012, 02:17 AM
I got the discs from the local hardware store. Ususlly they are used as end caps for welded tubes.
regards,
Frank
Old 07-10-2012, 03:23 PM
The discs are connected to one shaft...:
Next part will be the frame...
regards,
Frank
Old 07-11-2012, 12:53 AM
That is looking great. Will it be all brass?
Old 07-11-2012, 04:10 AM
I think so....some parts brass, maybe some Aluminum...
regards,
Frank
Old 07-11-2012, 10:09 PM
dabears's Avatar
dabears dabears is offline
Looking great!!
Old 07-13-2012, 02:38 AM
Some more steps forward...:
With the crank I can adjust the level of the hitch...
Regards
Frank
regards,
Frank
Old 07-13-2012, 11:21 AM
Look's great, Frank.
Cheer's, Neil.
Old 07-27-2012, 03:35 AM
A few days ago the parts fom CTI arrived...
The spindle cylinder for lifting the disc is now mounted.
regards,
Frank
Old 08-02-2012, 04:41 PM
Today I made the first test run of the lifting system...it works great with te cylinder!
To adjust the tilling depth I put the tractor 15 millimeter higher. In this position I can adjust the parallelism of the discs to the ground by turning the spindele...
If I find the time and the weather is ok I will make a video of the testrun outdoors in the next few days.
regards,
Frank
Old 08-02-2012, 09:07 PM
dabears's Avatar
Looks fantastic!!! Did an awesome job on it! Cant wait to see the video!
Old 08-05-2012, 08:24 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
great work ....
that cylinder is nice - better looking than the Firgelli styles....
Old 08-07-2012, 04:35 PM
First test run in (very) hard ground...
http://www.myvideo.de/watch/8694116/...is_9190_Test_1
regards,
Frank
Old 08-08-2012, 01:52 PM
dabears's Avatar
Cool video! Looks pretty good
Old 08-08-2012, 07:01 PM
Very nice work, Frank. The disk looks awesome. That hard packed ground isn't a good judge for the disk's functionality though. I'm sure it would work a lot better in a more scale, packed dirt field.
Old 08-08-2012, 10:17 PM
Video look good. I like the new tire setup. It looks like you need to adjust the hitch to have more rear dig. It looked like the rear was in the air and allowing the front to pull sideways and not cut like it should.
