#181
#182
HAHA Character.... it deff has plenty of character alright!
#183
Truck and trailer is looking good. Nice job on the tool boxes on the flatbed
Thanks for looking. All comments, suggestions, and constructive criticism are appreciated. Dave |
#184
Thanks Dave!
Leveled out the trailer tonight,re polished the front plate, and tore all the boards off... The shelving brackets are thicker then the wood so it won't work the way I hoped. I'll try grinding down some spots so it will this week. My daughter knocked my TX off the shelf it was on and broke the y training switch, lucky not needed right now, but took it apart to make sure no other damage happened.a few times after the radio when turned on would make a weird beep and all lights would flash...
#185
I feel your pain, my kids have the ability to knock over everything no matter how small or out of the way i think it is
#186
Well with the antisipation of parts coming in this week i did a little cleaning in the workshop this week so id have the room and could find what i needed
![]() Then i got the truck ready for surgery ![]() So today i came home to a package from Russ! ![]() ![]() ![]() He got it exactly the way i wanted it!!!! LOVE IT!! So i knew the time had come to make some mods on the truck so i measured 8 times ![]() ![]() ![]() Then got out the dremel with the metal cut off wheel.... ![]() Started cutting ![]() Fhew that came out good now the other side ![]() Just about 1 inch off on each side ![]() Test fit ![]() Then after breaking 2 drill bits ![]() cut the decking to where i wanted it and now here is the new rear end of the truck ![]() ![]() ![]() ![]() Now i have a lot more clearance room for the lowboy as well ![]() So now i need input on this..... few options i can go with it 1. Make all 6 turn signals 2. Make outer 2 turn inner 4 brake 3. Make inner 2 turn outer 4 brake 5. Make all 6 brake and move turn signals to the outer 2 on the light bar on the rack mount 6. Make outer 4 turn and inner 2 brake..... I cant decide now... PLEASE help me i dont have duel leds or all 6 would be brake and turn ![]() Also i plan on tying into the trailer portion of the mfu without the MFU trailer harness. but just for the brake lights... the turn will just be spliced into the original rear turn signal wires.... does anyone know which 2 prongs on that portion of the mfu do i want??? Thanks for looking!! ![]() ![]()
#187
Can't help you with the lighting, but the new rear light bar looks good
#188
Hey dabears, nice chop job and rear lights look great. In my opinion I would go with option #2 with turn lights on the outside.
I have the answer to your MFU question...just so happens that yesterday I removed the trailer lighting kit and can tell which wires are for brake lights. The wires are the blue and green wire. When holding the plug and looking at the wires and the connector lock tab is top side and away from you, the first 2wires starting from the left - blue , then green. Hope this helps, truck looks sweet. One of the best COE on site! Mario |
#189
the bumper looks great on the truck
#190
I love the light bar Aaron
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
#191
I like the bumper but not where it is at. I think you need to move the bumper forward closer to the back of the fenders. It looks like it is just hanging out there by its self.
#192
![]() ![]() Quote:
#193
Ok this is better! Took another 3/4 off the frame. I'm going to have to re work the tear fender mounts as its not going to work well like they are now but no biggie. Let me know how you like this way compared to the other way (not that I can change it now lol)
![]() How is this Travis? But I'll make them in black and a better fit? ![]() Thanks for looking and for the comments even if you don't like it be honest it helps me out!
#194
HUGE improvement. Looks alot better with the extra cut off
#195
Nice
#196
Yup , looks much better. Travis was right, I guess it was sticking out too much. Now it looks as part of the truck rather than something added on. With each thing you do to this rig it is becoming one of the sharpest looking Coe on site. The next build of the month featuring cab overs, I'm sure the voting will prove it!
One thing I would change though, I noticed the steer tires have a drive tire type tread pattern. That was one of the first things I changed on mine. I found a set on PMD that have a tread design which looks a lot more like steer tires. That's it, the rest is great. Mario |
#197
Hey Aaron, I retract my comment bout the front tires. I see you've had a couple different styles of front tires on it. It was a early picture from awhile ago where I saw the tire tread was a drive tire.....all is good ! Lol
#198
Thanks buddy! I like it better too, now its what I had pictured in my head
Thank you! Quote:
Hi my name is Aaron.... And i'm a truckaholic! Last edited by dabears; 08-04-2012 at 10:43 AM. Reason: spell check :) |
#199
I have to agree this is one of the best looking cabovers on the board, and the rear looks alot better the way it is now awsome job.
TONY |
#200
Looking great Aaron
![]() ![]() So when are you starting on your excavator to pull behind it on the low boy? ![]() ![]() |
