#101
I just looked it up and it is the JK falcon II motor.
#102
I'll make a start to get the Delta loader converted. Went to the toy store last weekend and bought the Delta Loader.
I just finished all my online orders for all the parts as per SmallHaul' shopping list (Big Thank You! for sharing that with the bruder conversion crowd). If this conversions works fine, I will try to convert the bagger as well. I could not leave the toy store without taking it home as well ![]() |
#103
Great, Thanks! just did the order as well so that completes the entire list. Awaiting the deliveries now...
#104
can i have one of those
#105
You can not ask to buy things in the open forum that is what the B/S/T forum is for. You also have to be a member for three months and have 50 post to use the B/S/T forum. I ask that you take the time to read the rules to make your time here a positive experience.
Thanks Admin |
#106
Scott,
Could you offer me any info/advice on how to modify one of the Bobcat brand T-190 skid steers toys to have proportional speed control. metman Mike in KY |
#107
Hey SmallHaul,
First timer here and I have quietly been working on my own bruder tracked loader conversion. I must say that things are getting pretty tight inside. I am trying to get everything to spec from your pics and advice that you have posted but it seems that I am just not quite getting the whole picture. My loader looks good and runs like a champ but I have only converted the driving part of it so far. Also, I can't close the body down all the way probably due to excess wiring. My battery is in the drivers compartment... I have thought long and hard about inquiring about one of yours RTR but at the same time, I don't want to give up on myself. I just want that satisfaction knowing that I did it myself... If this isn't a dead thread, and I really hope it isn't, than I would really like to maybe post some pics and get my build back in line... Thanks |
#108
#109
Love the conversion and thanks for the parts list that helps alot
#110
#111
I searched for the JK falcon II motor, on both sites, but I am unable to find anything. Is there a newer/different motor that you're using for this conversion now?
#112
It looks like the JK Falcon II motor is out of stock. You can look up the specs for that motor and get one that is within 5k rpm's of it and it will work fine.
#113
Thank-you sir, for that info. One more question, You mention shims for the Tamiya gearbox, Where does one acquire the shims? Are you referring to the brass inserts that are included in the kits, or something else?
#114
When you assemble the gear box check the gear contact from gear to gear. You want 100% of the width of the gear to be in contact with gear that it is driving..so, lets say that only 80% of the gear is contacting the gear that it is driving so basically you are loosing 20% of the gears strength. I use small shim washers to make the contact 100%. Hope that all makes sense.. you are setting the side to side contact not the gear mesh.
#115
Now I understand. Thanks for the reply.
