Old 08-22-2012, 11:12 PM
pigeonfarmboy's Avatar
Default Re: Snochaser's Construction Co. Builds
Ah yes they're out of the shop currently.
Old 08-22-2012, 11:33 PM
like the build very if you can find an armatron that had a grappler arm just an idea
Old 08-23-2012, 08:08 AM
Snochaser's Avatar
Where are they now? Any idea PFB? Travis figured out the servonaut on his and now I've got the sound like I wanted it. Awesome.
Ben
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 08-23-2012, 10:43 PM
Don't think there's any shows. Must be a vacation.
Old 08-24-2012, 10:03 PM
Snochaser's Avatar
I recieved one response back from ScaleART pretty much saying "our stuff doesn't have problems, sorry about your luck."
I hope to hear back a little more. I went and found some servos that will fit. I noticed the valve body had a sticky spot to it, so I rotated the valve around to an easily moved position. All is working with the hydros now. Fingers are crossed!
Next step is to contact Brixil electronics to figure out the operation of their pump control unit.
Ben
R.I.P. FGD
Never Forget- 343
Old 08-25-2012, 10:04 AM
Snochaser's Avatar
An updated....While I was taking in to get serviced.
and another before the operation started. lol
R.I.P. FGD
Never Forget- 343
Old 08-25-2012, 11:13 PM
apfubar apfubar is offline
Ben,
It does look good...
Which hoses did you blow? From the pump to the valve block or one of the lines to the rams? Just curious.
On the servos, as previously suggested also check the end points. On my excavator I check them every now and then (every couple of months) just to ensure they aren't hitting the stops and damaging the valves or themselves.
It will be interesting to hear how you go with Brixl stuff.
Cheers,
AP
Old 08-26-2012, 07:55 AM
Snochaser's Avatar
The first one was a bucket cylinder near the pump reservoir. The second one was right at the valve body.
I have looked over and moved done hoses around. The valves seem to operate easy by hand, the servos are at 100% on the radio now and don't appear to be over rotating. I ended up finding some Futaba servos that work. I'm going to put everything back together today and see if anything changes.
R.I.P. FGD
Never Forget- 343
Old 08-26-2012, 10:27 AM
Have you had to adjust the hyd press at all from factory? Does the loader arms lift as you push into the pile. What voltage are you running?
Old 08-26-2012, 11:34 AM
Snochaser's Avatar
No I haven't adjusted the pressure at all. I haven't notiiced any lift when running it.
Ben
R.I.P. FGD
Never Forget- 343
Old 08-26-2012, 01:14 PM
What I meant was will the loader arms lift the bucket as you push hard into the pile? And what voltage are you currently running? 3s?
Old 08-26-2012, 08:37 PM
Snochaser's Avatar
Oh, sorry. Yes it will lift as I push, it's pretty darn strong. 12v
R.I.P. FGD
Never Forget- 343
Old 09-19-2012, 04:15 AM
Claus's Avatar
Claus Claus is offline
That is probably the coolest model I have ever seen. Does ScaleArt offer a ripper for the rear?
That would be really nice!
Old 09-19-2012, 08:30 PM
Claus here is a link to a new loader that a member posted here that has the riper on it. Scale Art did a nice job on the whole model, they are a work of art.
Link click here.
Travis
Old 10-01-2012, 05:57 PM
Snochaser's Avatar
Just an update:
I think I've worked the bugs out. Did some additional cleaning up of the electronics, painted the cab. ScaleArt was great with all of my issues with it, helped me with everything, even replaced 2-servos for me. Haven't had any problems even digging in the dirt outdoors.
Ben
R.I.P. FGD
Never Forget- 343
Old 10-01-2012, 07:47 PM
woodhog's Avatar
woodhog woodhog is offline
congrats on getting the bugs worked out ,I know it must have been frustrating having such a nice model and not get to use it. But now you can get to work
Old 10-01-2012, 10:57 PM
Cool! What was it so others can learn from your mistakes?
Old 10-02-2012, 08:25 AM
Pedrocrisostomo Pedrocrisostomo is offline
Pedrocrisostomo is on a distinguished road
now a video to seal the deal.
Old 02-26-2013, 05:05 PM
Snochaser's Avatar
So now begins my new equipment build. A CAT 825H soil compactor
This is as close to my eyeball scale of 1:14 .
I laid out my pieces on 16g brass then started cutting
Stated soldering
Installed a RC4WD R2 2 speed trans and LRP truck puller 3 motor, I'm using AFV planetary axles (stainless wire is for locking)
body work is styrene
I will be installing full hydro's (steering and blade)
R.I.P. FGD
Never Forget- 343
Old 02-26-2013, 05:21 PM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Ben, this is very cool. Can't wait to see it one together.
