Old 11-13-2012, 01:55 PM
krankillen krankillen is offline
krankillen is on a distinguished road
Default tundra6x6 with Trailer!!
got an idea! a year ago. same time as the bullhead. built at same time.
started by ordering parts from all over the world. bought a frame and gearbox. had an idea it would be possible to make the six wheel drive.
wondered if I could raise the gearbox so I got more ground clearance.
Old 11-13-2012, 02:01 PM
Default Re: tundra6x6 with Trailer!!
ordered two rear sections, I could cut and extend it.
wanted to cut them here and there!!
Old 11-13-2012, 02:03 PM
went home to my brother in law to cut them.
Old 11-13-2012, 02:05 PM
this was my idea of how it would look
also bought two frames for extension!!
Old 11-13-2012, 02:17 PM
two become one! again!!
Old 11-13-2012, 02:21 PM
glued together rear truck bed!
Old 11-13-2012, 02:27 PM
now that I'm doing this. then I had no drawing! it was all in my head, the problems which arose were solved gradually.
cut the frame and welded them.
Old 11-13-2012, 02:32 PM
I was going to raise the gearbox. it started good .... but when the body was in place, then the gearbox was too high. redo, do it right! Now it starts to get complicated.
angle of the drive shaft became very sharp!!!!!
Old 11-13-2012, 02:40 PM
had to rout a new aluminum plate with a different angle. so I could lay down on the gearbox on the side.
Old 11-13-2012, 02:41 PM
I was going to use the original steering.
servo is moved from the side, in front of the gearbox instead.
Old 11-13-2012, 02:51 PM
is not so much images on the rear wheels. it will be rear-wheel steering. intend to use the original steering here. but had to remove it. I put a servo instead.
Old 11-13-2012, 02:55 PM
ordered a sound kit that would fit somewhere!!!
Old 11-13-2012, 02:59 PM
grind, grind, grind! a fifth wheel on the truck and a winch
Old 11-13-2012, 03:01 PM
Test assembly of body
took away the color of the shock absorbers.
Old 11-13-2012, 03:05 PM
tested where the speakers will fit.
Old 11-13-2012, 03:09 PM
a battery would fit somewhere!!
cut into the sound box, to make room for the battery.
Old 11-13-2012, 03:12 PM
tried to paint two colors on the truck, but did not get a good line on the colors
Old 11-13-2012, 03:17 PM
many cables it becomes!
buy rims for the truck! use the original tires. for they go well with the car
Old 11-13-2012, 03:20 PM
transmitter was ordered! it should be used to the gearbox and two winches, as well as the fifth wheel.
Old 11-13-2012, 03:23 PM
it looks like this now! rims have not installed yet.
