Old 11-18-2012, 06:16 AM
D8R D8R is offline
Default Re: CAT 374D L
Ari, nice looking cylinders. Du you solder the ends or are they glued to the tubing?
What pressure will you use in the system?
Dan
Old 11-18-2012, 09:21 AM
Dan
The pressure will probably be 20 bar or more, depending when my cylinders start to leak
Cylinders will be silver brazed, here's one that's been brazed:
Old 11-18-2012, 09:27 AM
mog mog is offline
wow you just keep out doing your self. what will hold the stick cylinder on a snap ring on the out side? are the bolts for the hose adapters end real or just on there and brazed on? thanks for showing us your work.
Old 11-18-2012, 06:06 PM
So what's the bore of the cyls and what size (ID) plumbing do you intend to use?
Old 11-19-2012, 11:04 AM
The stick cylinder and all the others will be attach with flanged pins that are bolted to stick.
Those M1.2 bolts are just for decoration, those hose adapters are brazed.
Old 11-19-2012, 11:07 AM
Cylinder bore is 18 mm and hose ID is 3 mm.
Old 11-24-2012, 09:37 AM
Made some plumbing today
Old 11-24-2012, 09:41 AM
Madda Madda is offline
Very neat!
What do you use for brazing?
Old 11-24-2012, 09:48 AM
Originally Posted by Madda View Post
Very neat!
Mostly silver.
Old 11-24-2012, 12:40 PM
rockNmayhem's Avatar
That brass and soldering work is phenominal!!! I sure wish I could solder that clean in that small of a fitting with brass. Can't wait to see this machine operating.
Keep it up.
Tyler
~Tyler~
RockSolidCustoms
Old 11-24-2012, 01:40 PM
tracksntreadslou's Avatar
Ari every time I look at this thread my Jaw drops ..You are really setting the Bar really high now ..Hats off so far a perfect peice of art
Old 12-07-2012, 11:51 PM
Got the boom boxed, and cylinders finished. Now I should get my hydraulic pump up and running to see if there's any leaks on the cylinder tubing.
Old 12-08-2012, 01:25 AM
Stunning!! Cant say more then that it looks fantastic, great job on the cylinders, hope they are leak free!
Old 12-08-2012, 05:09 AM
Beautiful job Ari! I'm sure that with your skills there will be no leaks.
Old 12-09-2012, 01:45 AM
I machined the tracks narrower, they are now 72 mm wide which is around 1 meter wide in full scale.
For my eyes they look more realistic now.
Here's a picture of the left track still wide.
Old 12-09-2012, 01:56 AM
Spot on! That looks so much better!
Old 12-09-2012, 03:13 AM
Here's both tracks done
Old 12-09-2012, 03:21 AM
aussie mack aussie mack is offline
aussie mack is on a distinguished road
Talking Re: CAT 374D L
looks great hemi loving the detail ur putting into it
Old 12-12-2012, 10:00 AM
D8R D8R is offline
Ari, looks better with the narrower tracks, the bigger machine, the narrower tracks it looks like.
This pic from a Swedish forum
What size is the L-connector on right side, M5?
Like your small connections (brazed) to cylinders, wish I had thought a little more about how to make those earlier. What´s the size of cylinders (good to know if I will build another hydaulic model, easier to find brass tubings).
Dan
Old 12-12-2012, 04:29 PM
super2222 super2222 is offline
super2222 is on a distinguished road
nice work
i would like to have more information on how did you do the track pad
Steve
