Old 09-14-2010, 02:19 PM
D8R D8R is offline
Default Re: D8R +463 in 1/5,6
Now I have got a photobucket account running so guess I can share more photos.
During last week I discovered a problem with the ripper attachment. When making the drawing for ripper, I took mesurments from a D8N but the upper part like fuel- oiltank and cab is from a D8R. Main difference between those models is that R-model has larger fuel tank and a new design on ripper attachment.
With my mix, upper cylinders hits the tank when ripper is up.
So lessen learn: never mix between different 1:1 machines.
I will make new drawing on brackets with new position for upper cylinders. At same time lower part will be redesiged to the clever solution of coupling my friend has. This will make it possible to have most of the drawbar mounted. In real live it´s foldable when not in use.
Yes, I have had some contact with "dozernerd" and the videos was nice, don´t know why they have been removed. Sorry because he has a good looking model that´s working well. He did use a 6hp petrol engine with generator and electric drive (maybee Cat got the idee to D7E from this model?)
Old 09-26-2010, 11:10 AM
D8R D8R is offline
Did build a carrier today to transport the D8 out of the house (no, will not be able to run it out, have wooden floor that gets bad). My workshop is located in ground floor but have a 2 step outside so needs a ramp to!
It is designed to take everything except front blade and arms.
Old 09-26-2010, 11:53 AM
pugs pugs is offline
Looks great! Just for size reference, how big are the "tiles" on your floor??
Jeff
Old 09-26-2010, 01:53 PM
D8R D8R is offline
Thanks, they are 15x15" and machine weight is about 320lbs as hanging.
Old 09-26-2010, 04:49 PM
modelman modelman is offline
Looking good! Is it ready to go? If so could you show us a video?
Old 09-26-2010, 05:04 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
WOW!!! Now that is a dozer!! Need to make a video of it running around so all can hear it running.
Old 09-26-2010, 05:17 PM
dirtpusher9's Avatar
Moderator
That is a cool device for moving it around, Dan.
Old 09-27-2010, 08:03 AM
td9clyde td9clyde is offline
Dozer Builder
Your rails for your tracks are cool did you machine those out or did you buy a small set for something else?
Old 09-27-2010, 08:54 AM
JAMMER JAMMER is offline
This is another great build can't wait to see this push some dirt it certainly isn't lacking for weight. Well let me see if I sell the excavator and the dozer and the loader I could get me a little OC3 Oliver to play with in the back yard I wonder if thew manager of the complex will mind. Ed
Old 09-27-2010, 10:22 AM
rc_farmer's Avatar
Master Builder
Holy construction 'Cat' lover Batman.........
Giving up is not an option!!!
Rob
Old 09-27-2010, 01:01 PM
D8R D8R is offline
Thanks guys for the responce!
No it´s not ready yet, have a lot of work to do before it can be started but will post a video as soon it´s running.
The tracks was designed in CAD to try to find a simple solution that looks like the real ones. The problem is that all commercial available chains has drive pin centered but a CAT chain has it a little offset. Well it´s a small detail but I decided that it was important for me at that time, today I have had gone a easier way.
Guess that finding suitable chain/tracks are as hard as finding tyres that can be used. To my 463 I found wheels with almost right dimension but of course with wrong pattern (I can live with that).
The parts are laser cut in 3-4-5mm steel, all parts mounted in a holder to be spotwelded and then the assembly goes inte a own to be brazed together (thats the color you can see between parts).
Each assembly is connected with a roller and 2 insex screws (next part is swiveling aroud the screw head. There will be some wearing on the parts but I think it will last for me (or I have to make new parts).
They still misses the 4 screws that should hold the plate, will be added later, but they have no function, only for the look.
Old 09-27-2010, 01:17 PM
Brian in PA's Avatar
I'd rather be truckin'
Wow that is sweet!
Brian
Old 09-27-2010, 03:15 PM
They look great!
Jeff
Old 09-27-2010, 04:21 PM
Very nice. I like the way you mortised the vertical piece onto the grouser plates. That definitely saved you hours of machine time. I guess you TIG welded them on and put a small tack on the ends and ground it down. What kind of steel is that? It looks like stainless
Old 09-27-2010, 04:32 PM
dozer dozer is offline
dozer is on a distinguished road
Heres an idea for your tracks. They dont look scale but they would work. Use attachment chain then rivet the treads to it.
Old 09-27-2010, 04:41 PM
Thumbs up Re: D8R +463 in 1/5,6
Those cats and rollers look great your doing a wonderful job keep it up when you get that old girl done you ought to be able to push some dirt for sure. Ed
Old 09-27-2010, 07:20 PM
Dozer Builder
that is cool thank you for lettin us know how you did it .....i don't have the cad programs so i do things the hard way lol
Old 09-27-2010, 08:50 PM
chaseracer's Avatar
amazing craftsmanship. simply awesome I can't wait to see this dozer redo someones driveway.
Old 09-27-2010, 09:34 PM
Tamiya Cowboy's Avatar
Truly Amazing work you have done on this build. I have seen and ran Joes dozer and that thing is big at 100 pounds but 320!! Holy cow that is outstanding dozer you have built..
Paul W. "Tamiya Cowboy"
Old 10-01-2010, 07:16 PM
Hammer Down Trucker's Avatar
Hammer Down Trucker Hammer Down Trucker is offline
Hammer Down Trucker is on a distinguished road
That is awesome is that engine a mower engine?
Member of the Central Plains Mini Truckers and The Spawn Of Cowboy.
Tags
1/5.6, big scale, cat, d8r, dozer
