Old 02-17-2013, 09:38 PM
D8R D8R is offline
Default Re: twins
Another fine digger coming up, Like that weight with the logo in it.
How many times do you have to change setting or can you make it all at once?
Dan
Old 02-18-2013, 03:17 AM
Default Re: twins
Az , Nate thank you
Dan, thank you , 1 setup as of now all done by 3D milling . I'm going to have to set it on the 2* taper from top to bottom to clean up the logo . A sin plate would be nice right now But , I'll make do . The bottom part I'll do a couple setups cause it's only 1" thick . I was going to flat surface all the angles with jigs . The 3D work actually ran pretty quick at 120 IPM with .5" ball mill . finish came out good for paint . The logo area took the longest , that I learned would be better on another setup
Old 02-18-2013, 04:36 PM
Default Re: twins
I let it finish up last night with the lights out then finished it in an hr this morning. this is 4/5th of it so far .
Old 02-18-2013, 04:46 PM
Default Re: twins
sweet!
Old 02-18-2013, 04:59 PM
Default Re: twins
Lookin good Steve.
What does it weigh?
Would it be too hard on tools to do it from steel?
I have nearly 11lbs of counterweight on the 850 and there are times it's not enough.
How far back from center is your counterweight? I'll measure mine to compare.
Old 02-18-2013, 05:58 PM
Default Re: twins
Lookin good Steve.
What does it weigh?
right now I got 13"+ to the back of the counter weight at 6Lbs I could make the bottom 1/5 in steel . That'll add as much if not more then what the 990 has . the 990's solid is around 12 lbs but I hollowed it out a bunch . I could've gone steel , but the wait will be forever till I get back on steel cutting since most the parts I do are in aluminum and the scrap yard does not like it mixed .
:edit: I'm finding it hard to believe only 6 lbs it feels much heavier . It has about the same cubic inch volume as a 20 lb sledge and feels about half .
Old 02-18-2013, 06:11 PM
Default Re: twins
13" from center pivot?
Mine is 9.5" & the entire length of the house is 16.5".
Old 02-18-2013, 06:31 PM
Default Re: twins
yes , from the center of pivot . From front of cab to back of counter weight is 17.80" X 10" wide . the counter weight is 5" high what is the diameter of your front idler and sprocket ? Mine are 3" major dia with a 2.6" DP for the sprocket .
Old 02-18-2013, 06:48 PM
Default Re: twins
Front idler is about 3", maybe a bit more... difficult to see clearly with the tracks on & me standing on my head to look.
Old 02-19-2013, 02:33 PM
Default Re: twins
LOL
All done now and a pic next to my 16 lb sledge
Old 02-24-2013, 01:27 PM
Default Re: twins
Oil tanks for both pretty much done . pics from raw block to finish tank . no pics of the chip pile .
thanks for looking
Old 02-24-2013, 03:03 PM
catmack catmack is offline
catmack is on a distinguished road
Default Re: twins
Steve,
Did you hog out the block for the tank and is that your filter?
What 3D software are you using and do you like it?
Old 02-24-2013, 08:32 PM
dabears's Avatar
dabears dabears is offline
Default Re: twins
But i wanted to see the chip pile lol crazy skills! Looks great!
Old 02-25-2013, 03:38 PM
Default Re: twins
Originally Posted by catmack View Post
Steve,
yes , yes , using auto cad I like It I learned on it . solidworks looks nicer but 2 things are holding me back from it : 1) compatibility with my existing A cad 2) price , I own A cad so it's not costing me anything
OK here you go It's nothing compared to what was in the pan before I ran the oil tanks (filled a 55 gal drum )
Old 02-25-2013, 04:06 PM
Default Re: twins
You need your own smelter now Steve!
Old 02-25-2013, 04:50 PM
tracksntreadslou's Avatar
Default Re: twins
.Holly Crap..That probably just one day too huh ..Hey nice work on the counter weight ..You are pretty much mastering that CAD/Cam thing steve
Old 02-25-2013, 05:43 PM
Default Re: twins
3 hrs running time. I had chips flying out of the top of the chip pan squaring up the blocks . I'm real happy with it now have to make 1 more for it's twin . I seem to be on the cad more and more these days
HA HA , Reg , yea I could start casting the daytons , It's just quicker to mill them
Old 02-28-2013, 02:30 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Default Re: twins
Nice work Steve
You are in the big league now, your skills are # 1
These machines will be moving alot on material come spring...
greg
Old 03-01-2013, 05:42 AM
FlyingBeagle's Avatar
FlyingBeagle FlyingBeagle is offline
FlyingBeagle is on a distinguished road
Default Re: twins
Very impressive.
Just curious, but for those of us who know nothing about machining, where does one buy a giant block of aluminum like that?
Old 03-01-2013, 06:22 AM
Default Re: twins
thanks Greg they should be ready for the fall time . At least 1
Originally Posted by FlyingBeagle View Post
Very impressive.
here you go but I didn't pay that much for what I used . I have an industrial surplus place near me that has drops and what not . but you gotta grab it when you see it .
http://www.onlinemetals.com/merchant...999&top_cat=60
