Old 02-21-2013, 07:28 PM
Default Re: Stahl 922 help
Originally Posted by Kaf343 View Post
Your thought on the motor wires make sense, I'll give that a shot over the weekend. It looks like they terminate on the left side of the ESC.
There's a motor terminal on the lower left & another on the lower right.
Old 02-22-2013, 06:23 PM
Kaf343's Avatar
Kaf343 Kaf343 is offline
I think we got er Joe, I switched the two leads on the small terminal strip for the right drive motor. Got both tracks going in the same direction. Messed with the pots a little more and no it seems to be functioning correctly. With Aux3 in either direction both tracks move in the same direction. When Aux2 is switched from center position to either up or down one track drops out.
The only thing I think I need to work on now is getting both tracks to turn at the same speed when moving forward or reverse. I've tried to fine tune with the pots but its still a little off, not to bad though. I marked both tracks in the same spot and ran them one full revolution and I've got it down to the tape marks ending up about two tracks off, not bad.
Thanks again for your help in getting me here. I really appreciate it.
Old 02-22-2013, 08:09 PM
You're welcome Keith, happy to help if I'm able.
I think sub trim of Aux 2 needs a little a tweaking which ever side to even out track speed.
Good to know that the Leimbach esc is capable of using a 3pos switch for steering... it makes sense to me now why the Sabertooth does not. Thank you.
