#161
It is getting really interesting now!
Kerst |
#162
One more small update. I struggled a bit to get the axles drilled out true but it's all done now. I installed bronze oilite bushings but I may put bearings on the outside end if it looks like it needs it.
![]() ![]() ![]() ![]() Thanks for lookin! |
#163
Those axles look great!
Kerst |
#164
Reg, if the axles pushed you out of your comfort zone, I can't tell. I know they aren't quite done yet, but it looks like you knew exactly what you were doing the whole time. I'll bet you had every step planned out in your head, before you even began. I might have missed it, but are those the Savage differentials?
Nathan |
#165
#166
Bead blast really changed their appearance.
![]() Now how did you rifle out the axle bores? You use the mill or lathe? Take any set up pics of that?
#167
#168
I wondered about that... once a hole is drill, how do you change its projectory over the length? ...small bits have so much flex to them.
#169
I drilled in from each side toward the center so luckily I only had the issue with the one axle tube. I installed bushings that are 3/8 OD so by drilling in very slowly with a 9.5mm bit I was able to get the larger bit to cut straight(almost) and in the end be able to press fit the bushings. Its a few thou out but you can shove a single axle all the way through both sides. It just doesn't turn as nicely as the other axle but I think it will be fine. When you put an axle into the diff gears from each side it spins freely. It definately made me sweat for a while though. I have way too many hours into these housings to wreck one now.
#170
I think you have CNC mill there that you aren't showing us, you say it's all manual but
![]() Keep the updates coming ![]() |
#171
Haha, Thanks Madda!
#172
Increadable, could never imaging doing an axle from a piece of stock material!
With your skills in welding I was supposed to see axle welded together from different pieces. And that you could get the bore it straight, thumbs up. Like that "cheese plate, do you have a pic without anything on it, guess have to do one of these, looks realy handy. Dan Last edited by D8R; 02-25-2013 at 01:43 AM. |
#173
Nathan |
#174
![]() looks good Reg . I see you can do abrasive machining too ![]()
#175
Haha, Abrasive machining is what I'm best at!
#176
A few minor updates.... I changed to bearings on the outside when I made the fake brake drums-backing plates. I have started making the rear leaves too but I haven't made much more progress.
Dan, Here is a picture of the plate that my father-inlaw made for me. It has an MT2 taper on the back to center it and is held down with 3 T nuts-allen bolts. I asked him last night if could make me a larger one sometime so hopefully he will. It would be nice to have a little more surface area. Reg ![]() ![]() ![]() ![]() ![]() ![]() |
#177
Wow Reg ..looking good..you and this guy have a little in common
https://www.youtube.com/watch?v=oOkmKkvC-PE |
#178
I would say very little. That guy has built a masterpiece...my own, not so much. Did you see the other stuff that guy has built? WOW!
#179
RCP57-this is some very nice work you are doing here. I have been watching this from the beginning and I enjoy these kind of builds--I am impressed!!!!
#180
I wish I had a father-in-law that knew how to machine stuff like that swiss cheese plate, Reg!
The drums on the axles really add a lot. Looking good.
Nathan |
Thread Tools | |
Display Modes | |
