General Discussion A place to post off topic discussions. |
#41
I think he was looking for something like shown in the following:
http://runnionequipmentcompany.blogs...r-trailer.html Cheers, AP |
#42
I hate the back-arrow/page back, costs me posts WAY too often!
Beat me to it Apfubar! I only know of one source for hese, and thats Bruder as usual. They have it available with trucks, but not separately like their normal forklift. And with less space inside, it would probably be much harder to adapt to R/C. BTW, for those who have done it, which forklift is the most economical to convert and have decent functionality. I know of the Very Expensive Robbe Linde H50 ($500+), the lesser Carson 'toy' Linde H40 (180 Euro), and then it drops down to the static Bruder Linde H30 (#2510) at $28 & Still (#2511) at $30, with the tail-rider type on the Bruder 'Mack Granite' logistics trucks at $130 for the green cab/white body (2820), and $80 for the all-yellow DHL (2819). Here is a pic of the Bruder tail-rider: ![]() Finally there is the pallet-truck, a hand-operated manipulator, thpough some higher-priced ones are powered: (#62200, $30) Opinions? |
#43
#44
I have replaced the Futaba S3003 standard steering servo with a Futaba S3305 servo because this one has a higher torque rating than the standard servo and it improves the steering on carpet, the S3003 servo struggled on carpet to give full lock,g I am also reworking the wiring inside the truck to get rid of the "Birds nest", also replacing the on/off speed controller with an ESC to give better control on the forks elevation/lowering
#45
some pictures of the work so far
![]() ![]() before the alterations to the wiring ![]() after the alterations, the two black connectors on the left connect to the two ESC's , the white one in the middle connects to the orange flashing beacon and the black one on the right is the main battery connection ![]() ![]() this is the type of ESC I am going to use for the forks lift/lower ![]() I have replaced the head lights and re-wired then to tidy up the wires in the truck, also going to shorten the servo leads to the tilt and steering servo and to the ESC's as well |
#46
![]() Last edited by Brel; 07-18-2017 at 04:43 AM. |
#47
Nice work on the forklift any videos of it yet
#48
thanks Justin Video uploading to you tube as I type this
#49
![]() Last edited by Brel; 05-29-2013 at 11:17 AM. |
#50
Would you check your link, I am getting a message stating the video is private.
Thanks |
#51
Sorry, I have altered the link to public now. don't know why it did that
#52
I have added a pair of extra headlights to the front of the cab using some brass tube and two 3mm white LED's and a resistor to reduce the voltage
![]() Last edited by Brel; 10-20-2017 at 01:51 AM. |
#53
very nice Brel..
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#54
Thanks Paul. there is more to follow in the fitting of reverse and brake lights, at a time when I get the time and parts to fit them
regards Stewart |
#55
the video gone? says unavailable.
#56
Stuff, I do not know what happened to the link as the video is still on youtube
try this link http://youtu.be/3ExgVJAX6B0 the video was shot before I added the extra headlights to the front of the cab Last edited by Brel; 11-14-2013 at 04:47 AM. |
#57
You've done a great job with upgrades and amazing details Brel. I like my H40 but your 50 model is such a nice looking forklift. Very well done!
![]() Mario |
#58
It's looking good I just finished building mine after a few months of owning it but I was just wondering if anybody is having the same problem as I am. When mine is running the cogs on the motor are very noisy is it because its too tight and I have to loosen it off abit I have put a ton of grease on it to try and stop it but it doesn't seem to. Could somebody help out to try and solve the problem?
#59
![]() ![]() Quote:
the lift gear on my H50 is quite loose, I used a sheet of paper between the worm drives and mountings on the mast to make sure that they would not bind up when I built it as you can hear in the video the main drive and lift gears are very noisy and I don't think there is much that can be done to sort out the noise http://youtu.be/3ExgVJAX6B0 |
#60
Hey Brel mine is roughly sounding the same as yours on the main drive and lifting gear but there is a guy in the club of ours that has one of these and I was looking at it the other day and his wasn't as noisy for some reason so I got to thinking that the gears drives might be to close together may have to be loosen off. I tried packing it with high volume grease but hasn't stopped it. It gets annoying after awhile.
Also how did you get so much tilt on yours because mine doesn't tilt that much? |
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests) | |
Thread Tools | |
Display Modes | |
