Old 05-29-2013, 05:23 PM
SmallHaul's Avatar
Default Re: Unit Cable Hoe
With Spektrum, the rx's won't work simutaneously, a model change in the menu is necessary. Is the JR or Hobby King rx's any different.
The way i understand it, as long as the rx's are the same, you can bind an infinite number of them to a radio at one time.
In other words for example: you can take 10 ar6110e rx's put them all in bind mode and then hold the bind button on your tx and turn it on and it will bind to all of them and control of them at the same time.
Scott
"No load is too Small"
Old 11-03-2013, 08:49 PM
SmallHaul's Avatar
i received a private message with a couple of questions...
The track chain is #35 chain with k-1 links on every other link.
The track pads are made out of aluminum nosing that is used for counter tops.
Folks, don't be afraid to ask questions in the thread you have questions about. Most people enjoy talking about their builds and don't mind sharing information.
Have fun!
Scott
Old 11-03-2013, 09:16 PM
dman10 dman10 is offline
dman10 is on a distinguished road
Thanks, also, how do they size the chain?
Old 11-03-2013, 09:42 PM
SmallHaul's Avatar
This explains #35 chain:
http://www.ehow.com/info_8079990_dif...-40-chain.html
The smaller chain that drives off of the servo is #25 chain and is actually very strong too.
i can't remember the place where i got the #35 chain with K-1 links from but, any place that sells bearings and drives should be able to order it for you.
Scott
Old 09-11-2014, 11:05 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Scott,
I just went thru this entire thread again, lots of good info, thanks!
Jim
Old 09-12-2014, 08:02 AM
SmallHaul's Avatar
Thanks Jim.
It is nice to have detailed build information to get more people to build equipment in this hobby.
Scott
Old 11-09-2014, 07:22 PM
Old Mechanic Old Mechanic is offline
Old Mechanic is on a distinguished road
Hi smallhaul,
I have been looking at some of your different videos and wanted to know if one take up spool runs free when another is moving the arm, or do you control each one at the same time with stick movement? In other words when one is taking in cable is the other spool running out under power or free wheeling? Hope you can figure out what I am asking about. If you do this with stick movement I would like to see a video showing the stick movements and the bucket & arms at the same time. It must keep you busy.
I have an old Unit Crane that was given to me for Christmas when I was 11 years old..... I am now 76. Did you make or buy the extension boom section on your drag line version? I would like to try a drag line version but feel the boom should be longer to get proper reach.
I really enjoy all of the info in your posts and am learning a lot. The are very good at explaining folks questions and what you have done to get the finished results.
Thanks a lot. Keep up the good work!
Old 11-09-2014, 08:12 PM
SmallHaul's Avatar
Originally Posted by Old Mechanic View Post
Hi smallhaul,
Hello Old Mechanic, Both cable lines are tight most of the time working together to control the stick/bucket... I have both the Unit cable shovel and the Unit dragline setup the same way. Here is a video from my old youtube channel showing the radio functions on the Unit drag line.
https://www.youtube.com/watch?v=1sm6...bBWIWHuSZKOPBw
Cable machines have a hoist cable (cable that goes to the top of the boom to lift up) and a crowd cable (cable that goes towards the machine to pull in).
So to dig with a cable shovel you would lift with the hoist cable and keep the crowd line tight to raise the boom/stick/bucket assembly and then rotate over where you want to dig..then let the crowd cable out to extend the bucket out and then let hoist cable out to lay the fully extended arm down on the ground..then start pulling in on the hoist cable and as you pull in if you don't let some hoist cable out the whole assembly will rise so, depending on how deep you are digging you might have to give more slack to the hoist cable. It is hard to get used to on a model and even harder on a full scale machine. The first time i ran a full scale drag line i couldn't believe how hard it is to run and a cable shovel is slightly harder imho.
You really do need to keep both cables tight all of the time so that they don't get messed up on the drum. With the small models it is no big deal if you let the cables go slack on occasion but, on a full scale machine letting the cables go slack for even a few seconds can cause problems and or damage.
I have the info for the guy that i got my boom extensions from if you would like to pm me for it. I don't want to post his number up.
You should convert your Unit drag line to rc though it will give you hours and hours of enjoyment.
Scott
Old 04-03-2016, 01:20 AM
Claus's Avatar
Claus Claus is offline
One of the great classic builds! Scott builds excitement.
