Old 11-25-2013, 10:35 PM
Bg416 Bg416 is offline
Bg416 is on a distinguished road
Default Bruder CAT 320
Hey guys, I've started my conversion. I've got my tracks done and the turntable gear is installed. I originally wanted to do servo screw drives and I cut the arms for the servos to go in. I recently changed my mind and I'm going with hydraulics now. I've filled in the holes with body fill and everything is sanded. I'm just looking for opinions on how I should make and install cylinder mounts. Also if anyone can help me with the installation of the hydraulic system it would be greatly appreciated. Sorry guys I will get pics up as soon as I can. Thanks in advance
Old 11-26-2013, 07:56 AM
pumptech's Avatar
pumptech pumptech is offline
pumptech is on a distinguished road
Default Re: Bruder CAT 320
Bruder sells a replacement boom,arm,and bucket section for the excavator on there website if you need .
Old 11-26-2013, 09:01 AM
cosworth34677's Avatar
well i found the if you use magons stuff he uses a rod and set screw. i re drilled the holes and put m4 bolts thought everything. also i would keep the mounting points the same. i have found that im starting to need to replace some of the plastic parts with metal ones
Old 11-26-2013, 10:40 PM
Thanks, I just placed the order and I got myself the bucket set as well
Old 11-26-2013, 10:43 PM
Yeah that's where I got them from. I'm just going to use the cylinder mounts that come on the bruder arm. Now the hard part.. Waiting.
