Hi guys,
I am Derrick, friend of Izzul. Previously, together we built the "1/10 Komatsu PC650" and were posted on this forum at: http://www.rctruckandconstruction.co...VATOR+MALAYSIA the cost to built the 1/10 is expensive and to travel the huge excavator is killing. some of the local rc fans had requested a smaller, budget-able and less-power version, the "1/14 Komatsu PC200" And the story goes on again... |
then every night on screen for CAD drawing...
RCEX_MARK02_ARM01_ASSM.jpg RCEX_MARK02_BOOM01_ASSM.jpg RCEX_MARK02_BUCKET01_ASSM.jpg Last edited by der82c; 01-23-2014 at 12:03 AM. |
and many more nights...
RCEX_MARK02_DIG01_ASSM.jpg RCEX_MARK02_TRACK01_ASSM_RIGHT.jpg RCEX_MARK02_UNDERCRAIGE_ASSM.jpg |
MOre and MOre sleepless nights...
RCEX_MARK02_HYD01_ASSM.jpg RCEX_MARK02_CAB01_ASSM.jpg RCEX_MARK02_MAIN_ASSM.jpg |
Not to forget those standard parts
PUMP.jpg SLIP RING.jpg CYCLINDER.jpg ooh, but the control valve is not from standard part, its custom made HYDRAULIC_VALVE_10BAR_MAIN_ASSM.jpg Last edited by der82c; 01-23-2014 at 03:46 AM. |
the fabrication of sheet metal
20131220_122026.jpg 20140103_170659.jpg 20140103_184325.jpg 20140103_174538.jpg Last edited by der82c; 01-23-2014 at 04:04 AM. |
mild steel arm and boom, sus bucket
20140103_184334.jpg 20140106_112550.jpg 1601984_198409260355404_1361406806_o.jpg 20140108_105308.jpg 20140108_105231.jpg |
Great idea putting the swing motor in the cab area, all too often a wasted area by other model companies.
![]() Steel fabrication is becoming more popular all the time & so much simpler to form & weld than aluminum... not to mention the weight advantage that these models are always lacking. The last pic of the press, is it a place where you work daily? Are you a metal worker by trade?
RCEX_MARK02_HYD01_ASSM.jpg RCEX_MARK02_CAB01_ASSM.jpg aluminum is light weight but don't have the strength, need up to thickness 3mm to nearly equal the strength of 1m steel. while my welder always quit worry on welding aluminum, tricky skill needed. while steel is less costly, but the rusting problem. epoxy powder coat will solve it. i am a CAD drafter in a sheet metal fabrication factory. so it was easy for me to done all those metal stuff. i do the drawing, while my guy do all the bending, welding, drilling and etc. they are experience and skillful worker, but sometimes they got me boil up my head when they create rejected parts. |
Very nice job. I really like the size of your excavator and the power. Ed
I'm interested to see how your custom valves turnout!
Cheers, Neil. |
250114-13.jpg 250114-14.jpg 250114-15.jpg look familiar, isn't? No, is not the one you think. still it is a same old spool-valve but internally i redesign the whole thing for better seal to prevent over-flowing, improving the fluid route and adapt for bigger size connector and hose. ease of attaching extra flange if needed Last edited by der82c; 01-24-2014 at 04:18 AM. |
Yes, looks very familiar
... so what size ID hose will you be using?
i won't stop, will push those pumps and valve to the limit. oooh yeah!!! |
ready to send for epoxy powder coat.
3 sets, as per request will be a black and white excavator. what?! 20140108_110416.jpg 20140108_110856.jpg 20140108_110954.jpg notice that, don't have any cabin cover parts in the pic, more story coming in. |
it's my first 3d-print out experience. it took me 7hrs just for waiting on this front-cabin cover done printed out. i still have to do the rear counter-weight cover and engine cover. how many long hours it is going take anymore?
No, i put aside this 3d-print for awhile, i need to install those metal parts now and have the system running, on priority. 20140106_230050.jpg 20140106_230119.jpg 20140106_230133.jpg RCEX02_CAB01_viewA.jpg RCEX02_CAB01_viewD.jpg |
Very nice work!
got those sheet metal parts back from powder coat
20140113_143136.jpg so does partial of those machining parts. while my factory will have the tools and machine to do all those sheet metal but do not have the facilities to machine these parts. luckily i can always get help from next door. the cnc machining workshop is just next to my work place. 1518776_199562403573423_11033238_o.jpg 20140108_130347.jpg i lay out all the parts i got today, it's look like a complete set but no, still some critical parts the machining shop owe me. 1040183_201881493341514_1963447427_o.jpg oh well, chinese new year is just few days away. all works at metal shop is shutting down. i need to get prepare for the festive. i think i will just put on-hold for 10 days holiday. |
how are you? how is the progress of your excavator? it will be slightly ease for me on this model since all the pain i got from the PC650. tell you a secret, we nearly gave up that time, problem keep occur one by one, sleepless night thinking of solution. lack of experience. but still there a challenge for this model as it's a PC200 which i had to squeeze in all the system in to its small compartment. how about this way, Kevin. i try my best to finish this a.s.a.p in order to bring this model to SG, to play along with yours. how is that? by that time you must too able to finish yours , ok? Happy Chinese New Year! to you too. wishing you have a prosperous yearS Last edited by der82c; 01-25-2014 at 10:40 AM. |
