#161
Very realistic picturels
#162
Thank you very much guys. I still have some details and paint to add on the skidder but I must say that I am happy to see it fully functional. I think a smaller hydraulic pump would be a nice addition as I have the speed dialed down a lot on this one. I also need to invest in a better battery. The 5aH lead acid doesn't run for long before it dies and it's added weight really isn't necessary on this machine. I added foams to the tires yesterday and that seemed to stop the crumpling on the rears.
Does anyone have any experience using the complete pump setup from RC4WD? I think it is around $225 for the pump and motor but I have no idea how much oil it moves. I need a fair amount of volume for this, just not as much as I have now. ![]() Reg |
#163
I like your pump. How did you do it?
#164
I didn't make the pump itself. My father in-law machined the inner case on a cnc mill to fit some internal gears that I had and then I machined the outside down as much as I could to decrease the size. The gears are from a motorcycle oil pump and are more designed for volume than pressure but it still pumps 25bar with ease. I'm not sure how long the aluminum case will last. It was our intention to try this pump and if it worked, make the cases from brass or steel. I have another case just like this one and a few sets of gears so I can make one more if this one wears quickly. My current drive setup is the original from my excavator and spins the pump way too fast for this machine. Pump speed is close to 6000rpm if I don't dial it back and the pump makes a lot of volume. I need to get a lower KV motor because the speed control gets hot running at a reduced speed all the time. Either that or get a smaller pump, hence my question about the RC4WD pump and motor.
Reg |
#165
Glad to see you have your model working, as always a work of art. The hydraulic valve working with just minor leaks is what I've been waiting for, now its my turn to copy your build and build my own for the l2350 I have under way.
Thanks Earl |
#166
Yes the valve seems to work OK with no leaks now that I used some loctite between the halves. I could have machined grooves for O rings around each valve and that would have been better but I was lazy.
Any chance you will be taking the ferry ride over to the island next weekend to attend the Atique truck show with us Earl? Lets see some pictures of your build! Reg |
#167
Another great build!!! Watched the vids earlier today....NICE.....
You need better foam in the tires if you're going to always haul those big logs around...LOL...again nice job man well done!!! KP |
#168
Thanks KP. It needs some work but I'm happy to finally see it fully functional. I put some foam in since the videos and there's no more flattened out tires now!lol
#169
I have been waiting for some motors to be in stock at the Robot Shop for months. They are supplied by Servocity and I could have bought them there but for some reason their shipping to Canada is really expensive. Anyway, a while back I made an order from RS and they had 1 in stock. I need 2 motors but I thought 1 was better than none so I bought it to try. Here are the results of changing the motor....http://youtu.be/LtbxUR9raN0... I guess I will order another but I'm not sure how useful it will be. Maybe I should glue the rear tires first...
#170
#171
No such thing as a copy cat. Each machine is hand built and unique to each builder. Big fan of Tigercats, wish they got more recognition
#172
Thanks guys. This build was a real challenge for me. Not in the sense that the pieces were too hard to make but I just struggled to stay working on it. I lost interest in it many times because I was too lazy (and afraid) to make the cylinders. Once I actually put my fear aside it was fine and I'm so happy that it is finally functional! It still needs some tweaking for sure but I don't think there are too many 1/10 hydraulic grapple skidders out there so that makes it unique.
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
