#541
Sorry about double pics, working from phone
![]() I think I figured out how I can use the actuators I have, thanks to the advanced prototype tools I have. ![]() ![]()
#542
#543
After eating too much for bday dinner I tried to get some more done but it's couch time
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The top shaft will be able to pass from side to side, the bottom will be two separate on each side as actuator will interfere with it. Trying to make it torsionally stiff as possible.
#544
gettin better and better each day
#545
That scissor neck is coming out sweet. I like it! Good job
#546
![]() ![]() ![]() Getting towards the end ![]() ![]() ![]()
#547
#548
Both the trailer and napoleon are lookin good . What is the height of your I beams in the trailer deck ? Mike
#549
Thanks for the complements guys, like I've said my welding skills are quite a bit rough but almost all will be hidden
![]() Mikem, the I beams are almost one inch tall. I did not look into actual dimensions of trailers, just went with what I thought. The panoramic pic has distorted it quite a bit. Tomorrow I will try and get a better one. I know I'm about to run into a problem with the actuators, the top (black plastic housing) is just a bit taller than what the decking will be. One of those things of my redneck engineering, measure after you build it,,, then engineer some more ![]()
#550
That's awsome that's all I have to say!!
#551
Put a live roll on the back of trk frame & a winch behind trk cab, then the scissor neck will function like a real one.
#552
This is what I'm aiming for joe ![]() ![]()
#553
http://youtu.be/WRoj1bkmcxc
And another video I found. Now how cool will that be? Stay sitting in my lounge chair and not have to unhook anything!!! That's why I was going to make this have its own radio system. Just have to install a fifth wheel unlock servo in the truck and I'll only need to get up to pee or refill beverage. ![]()
#554
#555
http://youtu.be/6FWF0a1Rt7w
Finally got it figured out somewhat!!! Still need to limit the lifting legs so the neck will elevate completely. But it is self contained rc!!
#556
Putting a floor on the main deck, would that work for leg stops?
Looking good. ![]() Turn your Iphone a 1/4 turn when filming. ![]()
#557
![]() Yes putting 1/8" thick bass wood on for decking. But I am going to place a metal stop in frame rails to facilitate the landing legs to stop and allow neck to raise higher. I still don't know if two actuators will be enough power to lift when 60# plus load on. If not I can add one in middle or two. Haides or high water I'm bound to make this work!!!! Also have to figure out the movable kingpin. That might just be gravity to facilitate that or simple spring band. Figured you guys have remote quick change buckets for the excavators, so when I'm not around the easily motivated kids to unhook something I can still enjoy my lounge chair ![]() ![]() ![]() ![]() ![]()
#558
![]() The king pin was in a tube and was gravity activated. It was a 4" pin (read heavy) vs. a standard 2" pin. I would think you could do the same, maybe add a lite spring to make sure it drops when it needs to. ![]() |
#559
Cooper why don't you use alder as opposed to basswood it is harder nice grain and would take a 60 # load better load . If you want some email me off list with a list . Mike
#560
