Absolutely mad skills you have with that welder! I'm intrigued with that motor/gearbox setup - any more pictures of that small conversion?
Glenn |
Thanks. The roof was/is a little tricky and I'm not sure I have enough "dome" in it but it will do. I don't know who did the trans for sure(Heavy Duty maybe) as I got it in a trade. It has the motor swapped on backwards with a small reduction added using a jack-shaft. After some careful filing of the mounts it runs smooth and has reasonable speed using a 55 turn motor. It would be nice if it were slower but it seems to run about the same speed as my KH using a stock trans and 85 turn motor only it has a lot of power. The KH with 85T is horribly gutless.
Reg |
i swapped out my rc4wd 80t for a 65t for that reason no power
i wish i could work metal like you do reg!!!! |
I've been going crazy in my shop the last week or two. Lots on the ta-do list and I'm feeling it
![]() ![]() ![]() ![]() ![]() ![]() Reg |
Very nice reg, admire your skill, thanks for the pictures and sharing your knowledge.
David |
#26
looks verry well - awesome
Everything which is round rolls well, I´m round... ...so kepp on rolling, keep on trucking!!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Greets from Germany Martin |
#27
I'm new to RC construction and found your YouTube site and enjoy your postings. You are a true craftsman and an artist. If it doesn't give away to many secrets, what is your welding setup? I am in awe of your work.
#28
Thanks very much guys. I'm happy to share what little knowledge I have. I am afraid I am no expert and just learn as I go so my knowledge is limited. My welding setup is no secret either, it's just a Lincoln Precision 225 TIG. It came with a lame instructional video and boat load of patience.
#29
Jason |
#30
![]() Last edited by RCP57; 05-20-2015 at 10:32 AM. |
#31
Im with ya there, Thats good advise. ![]()
Jason |
#32
Looking great so far as always, still in awe of the self made five-holers
Make peace or Die! 1st Bn 5th Marines |
#33
I noticed the ribs on the doors, it looks like you soldered them on, or did you shape them with a bead roller? Either way they turned out great.
#34
![]() ![]() Quote:
I hope to have some more updates in the next couple of days. |
#35
I'll keep looking. You do massage the metal very well.
Life: it's all about the ride! |
#36
A small update. I spent the latter part of the afternoon and evening machining the rad and then bending up the hood. The hood still needs work but I had already been in the shop for too long and was hungry.lol
The rad started out as a piece of 4"x1/2". ![]() ![]() You might be wondering why I machined out so much of the core area but left some.... The answer is.... ![]() ![]() Then the hood ![]() ![]() Looking more like a truck now! ![]() |
#37
Absolutely beautiful work! Hard to believe you just start out with a sketch on a piece of paper! Love the little details you've already put in place.
Respect! Stephan |
#38
A little update. I got the rad and cab mounted and the hood fitting fairly well. I also added some detail to the hood. ![]() ![]() ![]() |
#39
That's looking real good. , what are you doing for a grill? Working Louvers?
#40
![]() ![]() ![]() Here's a little update from today. Not much really but I did receive some stuff from the UPS man today. Most of the package was not for me but I did buy myself a new set of tires for the truck(Thanks Alex ![]() http://youtu.be/ri5SAp7TBb8 Some inside/outside shots ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
