#61
looking good. Maybe add some axle stops so you can control the articulation? I cut mine of the tamiya axles so I can get more but it looks like you will have plenty!
looks like your bed lift will work just fine. If I can offer a suggestion. My Piviot point on my green MACK 6 Wheeler is about even with the back of the rear tire. I had it previously further back about 10-15mm but the truck was trying to do a wheelie when dumping or with the box all the way up. you may want to check to see if your truck will stay solid on the ground with the bed fully raised. It looks like you will be fine with a heavy truck but its something to think about Hope to see this at the spring meet!
MACK
"The Greatest Name in Trucks" |
#62
I have your build thread saved in my favorites trying to study how it hooks up. I understand how it works but trying to figure the right place to put it without drilling a bunch of holes and moving it around so it doesn't get into the suspension etc. etc. is pushing me closer to building a set of dummy rails to test all the possibilities ![]() ![]() ![]() Last edited by TRUCKMAKER; 04-05-2015 at 06:51 PM. |
#63
I can measure where I drilled the holes when I get home next week. Send me a PM on Thursday if you want the info from my truck. I think I used one of the three stock trunnions holes on the frame rail for the pivot point of the lift then just drilled one hole in the bed floor for the other end of the lift. The screw drive pushes and the lift unfolds and moves pretty quick as you have seen. I got lucky that the lift tucked I between the axles and did not interfere with suspension travel. I think you will have plenty of room to work with.
MACK
#64
#65
I was surprised how well it lifts a full box of sand even when the whole lift system is connected at the rear 1/3 part of the box.
I get a little over 45 deg if I recall correctly. But trial and error was how I had to set it up. Just let me know if you want any measurements. Trent
MACK
#66
Got the bed lift motor mounted. I'll try to wire it up tomorrow. Need to get some limit switches.
![]() ![]() ![]() Thanks for looking! Kent ![]() |
#67
I got the dump body lift wired up and ran a quick test. Due to the way I wired the limit switches I couldn't tell whitch end was which and of course a 50/50 chance and I got it wrong, the motor tried to turn this thing inside out
![]() ![]() But here is a quick video of it the way it's supposed to work ![]() ![]() ![]() http://youtu.be/tj4BE-vGd6U |
#68
Says the video is private?
MACK
#69
Try it now and let me know. I don't do a lot of videos and I didn't set it correctly
#70
Vid opened fine.
Wow. I'm anxious to see this with a load on it. The multi link plays with my head on the triangulation of the lift forces so it intrigues me. |
#71
After the first time I seen this one online and then on LMacks truck I googled it and found that there are 1:1's just like it that use a hydraulic ram in place of the screw drive. I'm anxious as well, the box is pretty large compared to most I've seen so it will be interesting to see what happens. I'm hoping to have it far enough along so we can test it the weekend of the Franklin toy show.
#72
Oh we will test it whether your ready or not
#73
#74
Here's a few update pictures while getting ready for the Midwest Spring Meet next weekend May 23-24. The dump body is still drying and a new one will be made and hopefully be done by Indy along with the correct bumper.
#75
Here's a couple pictures and a video. The second picture shows the battle scars it received at the Midwest Spring Meet In Monticello Ill. this past weekend. It worked really well, far beyond my expectations. The battle scars are due to it being slightly top heavy when loaded and a crazy driver! We had a great time at the meet.
I'm hoping I'll have the new dump body done by Indy as the body on it was originally for a pup trailer hence no cab protector. https://youtu.be/Y4ahTGC6YkM ![]() ![]() ![]() Thanks for looking, Kent |
#76
Looking good Kent!
![]() Some your battle scars come from Nate loading ya?
#77
![]() No battle scars from Nate, he's one of the smoothest operators I've seen ![]() |
#78
Battle scars were from Izzy and his new excavator and wheeled loader. Amazing how we all loose stick control without lots of practice. Still better than using a shovel
LYNN |
#79
#80
I dont mind putting my trucks to work and getting them dirty.
Scars on the other hand..... I'm not so comfy with. ![]() The truck looks and works great Kent . Nice job, I'd love something like that in my open pit. Last edited by Supermario; 05-28-2015 at 04:19 PM. |
