#1141
Truck maker ,thanks for the post number missed a couple days of due to rib issues . Cooper when I use to moulding I got rid of those tiny bubbles you have at the top by putting it in a vacuum pot it worked well . Mike
#1142
#1143
this what you did for the d11?
#1144
Yup, same thing, bit the bullet and bought one of those models, scaled off of it. Also various pics, company brochure , and shop manuals. Pics from Mario will help. (Would be nice if cat would give me access to detailed manufactuering blueprint) blahhhhahahah
#1145
Have you looked at this : http://www.the-blueprints.com/vector..._mining_truck/ You R doing AWESOME work Carry on ![]() |
#1146
R W you might want to take a look here too. On page 17 there's a three view drawing of your truck. Load it on a zip drive and take it to your local copy center and have it enlarged so the axle wheel base is 14.571 and you'll have a drawing you can measure strait off of.
Good luck, she's going to be big!!! 32.5 L x 16" H x 19" W http://s7d2.scene7.com/is/content/Caterpillar/C637177 |
#1147
#1148
Well I wasn't sure about power of the gearhead motors I got, so I got some new ones in mail, they are .55horsepower each. They should move it fully loaded
![]() Steve, thanks for the kaydon bearings, they are the slim type I was looking for, but,,,,, those little suckers are $100 or more for one!! Changed my ideas around on the axles to suit more practice bearings. I have almost 6" between rear tires and duel wheels spread almost 5" so plenty of room to hide motors/support bearings and anything else in rear axle. I also thought about 1:5 and 1:8 scale gas RC trucks rear differentials but I'm thinking they are even small for this!! And the gearhead motors I am getting have a 1/2" shaft, 1 1/2" long. Keyed and end hole tapped on shaft. That will make a really solid set up for removing load from motor shaft to the truck axle.
#1149
This thing is going to be almost 3' long, 18" wide and with dump bed raised almost 32" tall. This may be on the limits of what I can comfortably carry around. !!!! One thing about this is it is a fast mover compared to the dozer, as long as it's is running I'll be using it to move me possibly!!!! I'm just guessing here but I imagine it should be able to haul about a five gallon bucket of material. Should be built to support 80 pound load or more.
#1150
glad to see it all coming together brother, cant wait to see this bad boy i action!
#1151
And don't forget the battery weight and size. Probably going to need a good sized one for decent run time. Or maybe wire up a whole bunch of those lipos you got should work.
![]() I'd hate to see you strain your back carrying the beast. Better build a tow cart or something for behind the ATV? ![]() |
#1152
Hey Cooper !
This might avoid future BackPain Just train Mr Nutter to drive The RockBeast and the transportation is solved. Roll on roll off :https://www.youtube.com/watch?v=OPdCDj_RiKI Last edited by Bo Wallen; 11-09-2015 at 04:55 PM. |
#1153
Good idea Bo, but mr nutters has moved onto another worksite, he now works for the forestry department
![]() Well I know I got the pigment right this time. And I mixed for 1 min, immediately poured and had the mold slightly unlevel, tapped mold, basically did everything I could to eliminate the air. Time will tell, about two hours and I get to see if hero or zero!!! ![]()
#1154
Drumroll, Please !
#1155
#1156
SCORE !!! You Sillycone Guru
#1157
the tire is as tall as the aeromaxxxxxx
epic build going on here!! back to my little kat |
#1158
Impressive cooper . I think you'll be able to put all my trains in the box ! Mike
#1159
May Santa bring you a box full of hero cookies! That is awesome my friend!
#1160
Nice! They barely look like a permit load.
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests) | |
