Soyland Industries Custom developed models & parts regarding 1/14 trucks & construction machines |
P/N 22002 Track motor upgrade kit
340 USD, + shipping 40 USD worldwide (cost does not include VAT, sales tax etc that may be added at arrival in your country) Track motor upgrade kit for Eagle JD-1/4200XL excavator (‘RC4WD Earth Digger) These upgrade track motors will give you considerable higher power & more suitable max RPM than the original track motors. Original track motors has often be experienced as underpowered and the spur gear transmissions is one of the weakest points. The upgrade kit has industrial planetary transmissions that will take considerable more ‘beating’ than original transmission. NOTES: ******************** 1) UPDATE 10 March 2018 : Kits now delivered with outer diameter of motors turned down to 34.7mm, for direct mounting on both version 1 & 2 of the 4200XL, that have some variation in the track motor bracket's bore 2) The motors are NOT prepared to run submerged in water. The motor covers will protect from light rain and splash of water, but water will get into the motor if submerged. If getting submerged by accident, stop running at once, take covers off in order to let the motors dry out. ******************** Kit includes; • Planetary brushed gearmotors, 540 size motors (5000 rpm), output ~45 rpm max (versus original gearmotors ~20 rpm) • Cables and minor electrical parts (existing motor cables in the undercarriage will be too short for the new track motors) • Instruction manual (English, electronic) (• Compression springs can be delivered as an option if one got the older version of the 4200XL with no original springs. 20 USD for a kit incl brackets) Advantages too available brushless track motors upgrade kit on the marked; • Less complicated and time consuming installation. No need for separation of undercarriage and upper structure in order to replace centre electrical slip ring • More stable running of the tracks at ‘low trottle’ and more control than the brushless gearmotors which are relative high geared (60 rpm). • Reduced problems regarding the tracks start rolling during digging operation, as can be experienced with brushless motors which are dependend of well functioning electronic parking brakes in the ESC’s. Brushless motors do not have the internal resistance against rotating, as is the case with brushed motors. • The original brushed motor ESC’ can be used, and not to be replaced as is case with the brushless motors kit. Pictures: http://www.rclastebilbutikk1.no/tilb...wd-graver.html Last edited by Rimrock; 09-11-2020 at 05:32 AM. |
I would be interested in thread and more info. Thanks
Sweet upgrade Rimrock. Do you have a before and after video of the modification ?
looks good rimrock!! let me know when you tackle the china kat also
Thanks guys) I guess I will open a sales thread in near future here with some more info, I also have other stuff in the coming. Should have some videos, definitely. Will try making a couple of videos, at least the 'after videos' of this machine, that's with a local customers now.
The KAT excavator, yeah that's one of our other acquaintances from China, 'we love China' ![]() Last edited by Rimrock; 02-25-2016 at 09:23 AM. |
one of the guys in my china kat thread blew up two sets
David |
Hi Rimrock,
I also own a Buychina Kat as well, If you were to make idler wheel kit with Retrofitted compression springs and a set of upgraded track gear motors for the buychina, I've would be happy to buy a set of each off you. I bought my Kat around Xmas 2014 and I still have not got it up and running yet, due to work and life getting in the way and my replacement slip ring getting lost in the mail for 3 months. Regards Cam.
Sees no evil, Hears no evil, Speaks no evil To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Oyvind |
once you have sets available for the 4200 I will defiantly take one. Stock stuff is done and need to fix.
A video of one 4200 with the new track motor kit. It's running here up to about 2/3 of full speed. Possible limited speed, in % of full, can be set on most radios. Pretty good torque from those motors, one need a very strong grip to stall them by griping the tracks with one hand) Planning to have some new kits ready for sale in April,
https://youtu.be/60gSjtnwJog |
That 4200 moves around with ease! Great job Rimrock
Definitely keep us posted. I'm in for the motor upgrade and new tensioner when available.
Hi all, busy days with different projects going on parallel here
![]() For ordering, just send me a PM, and we take it from there |
PM sent
PM sent
Woohoo can't wait to put my ho to work with these new stronger motors!
You get yours installed yet? mine are still a couple weeks out.
No not yet parcel is still in transit.
